Old 03-09-11, 01:54 PM   #11
mikerj
Default Re: Cam chain re-adjustments
It sounds like the spring has broken. They are not really "user serviceable" parts, certainly you won't be able to buy a new spring. The tensioners on the 99-02 bikes are known to be problematic - now is a good time to fit some later ones.
Old 03-09-11, 02:31 PM   #12
They extend as you remove them, that is normal.
How are you adjusting it to make it tight?
Old 03-09-11, 07:46 PM   #13
mikerj
His doesn't extend by itself, that why I suspect the spring has broken. He mentioned that he adjusted it out with a screwdriver - but obviously without the spring it will quickly work it's way back in.
Old 03-09-11, 08:47 PM   #14
Destruktor77
Yeah that's right, I set it correctly with the screwdriver, and it doesn't move in my hand, but when I put it back in the engine it managed to retract back in.
So yeah, new one then... K3's, might as well replace them both if I can get a pair.
Handle bar adjustments LK-SV SV Talk, Tuning & Tweaking 4 09-09-09 03:21 PM
Carb adjustments? skyline Exhausts 0 23-06-08 11:06 PM
Fork Adjustments silversurfer SV Talk, Tuning & Tweaking 0 04-05-08 09:23 AM
New '06 650S - Adjustments Needed chuckjones SV Talk, Tuning & Tweaking 8 04-04-07 05:08 AM
How much for dyno + adjustments, and where? Saracen SV Talk, Tuning & Tweaking 2 11-01-06 08:11 PM
