#11 |
So what will actually happen then? Will it kill my bike to ride it with out the Reg/Rec fitted?
I am aware the battery will discharge like mad, but I can deal with that if it is the only side effect. |
#12 | ||
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
#13 | |
Get a CBR r/r they're a common upgrade. |
#14 | ||
Occam's razor- wires entering unit have got damaged.
Usually it happens at the connector block, but it doesn't have to, that spot will do the same, shorted wires have got hot - with the result you've seen. This is a mechanical failure of the cabling - not specifically a failure of the regulator rectifier. CBR unit will work, but is far from the only unit that will be fine - I'm constantly puzzled why there's an obsession with that specific unit. Quote:
PS: GS regulator OK on SV, (except that one obviously, it may be a dab past its best now).
#15 |
Could some one please have a look at this item number on eBay 190441336589 and tell me if this will be the right type?
Thanks! |
#16 |
Yes.
#17 |
Why not go for one off a GSXR? Cheaper option & does the same job.
Here are a couple on Fleabay. http://www.ebay.co.uk/itm/suzuki-gsx...item3f0e1c7cc8 http://www.ebay.co.uk/itm/SUZUKI-GSX...item1e66ef43e3
Flickr: http://www.flickr.com/photos/croozenooze/ Facebook : https://www.facebook.com/colin.hughes.1213?ref=tn_tnmn Yoo Toob https://www.youtube.com/channel/UCjG...eMWUx4Ud2dK-yA |
#18 |
Running without a reg will stop charging, you will be running total loss (like a race bike). Slowly the charge in your battery will reduce and affect the spark being generated. Eventually your bike will cough and sputter and grind to a halt when the spark is too weak to ignite the fuel.
#19 | |
How long would this take to happen? The battery is brand new, I fully recharged it with a trickle charger for over 12 hours over the weekend. I want to do 4 x 4 mile journeys today. |
#20 |
With my Triumph it did about 10 miles before dying completely. The lights started to go after about 4 miles, then the clocks registered 888 after about 8 miles, then it stopped
Regulator | wilky007 | Stuff Wanted | 1 | 08-06-09 05:03 PM |
Where is the regulator | philbert | SV Talk, Tuning & Tweaking | 7 | 26-09-08 05:21 PM |
Replacement Regulator Wiring | Tris | SV Talk, Tuning & Tweaking | 5 | 24-04-08 12:55 PM |
It must be the regulator... | NadineDieBiene | SV Talk, Tuning & Tweaking | 7 | 05-11-07 01:06 PM |
