Old 06-12-11, 08:46 PM   #11
robh539
Default Re: Would you get wetter...
yes ran thought it.
Here one for you is glass a liquid or solid?
Old 06-12-11, 08:48 PM   #12
Dave20046
Dave20046's Avatar
Originally Posted by Red Herring View Post
I think if you run in it for a minute you get just as wet as walking in it for a minute....the advantage of running is that you're only in it for 30 seconds....and it's only your front that's wet!
exactly
Old 06-12-11, 08:50 PM   #13
hongman
But if you run, surely you hit the rain faster, resulting in being wetter? Weather (lol) this is enough to tip the balance I dont know.
Not quite sure how one would scientifically test this though.
Glass can be both, depends how hot it is .
Old 06-12-11, 08:53 PM   #14
MisterTommyH
MisterTommyH's Avatar
Glass, at normal temperatures (i.e. your windows) is a liquid - albeit supercool.
If you took a micrometer and measured a section of a 10 year old single pain glass window the bottom would be thicker than the top - even though it started off being uniform thickness.
MisterTommyH is offline   Reply With Quote
Old 06-12-11, 08:54 PM   #15
Dave20046
Dave20046's Avatar
I don't think the added drive would be substantial enough to out weigh the time exposed..... Ussain?
Old 06-12-11, 09:30 PM   #16
enzoalex
You get hit by exactly the same amount of rain per second, whether you are running, walking or standing still.
So because it takes less time to get places when you are running, you'll get less wet. Simple
Old 06-12-11, 09:33 PM   #17
robh539
correct runing though rain makes you wetter as driving it into clothes.
Yes in all states glass is liquid has no crystalline struture so it flows very slowly as tommy has said very old windows are thicker at the bottom.
Anybody know the answer to this: when is water at it max density?
Old 06-12-11, 09:38 PM   #18
enzoalex
When it's just about to freeze?
Old 06-12-11, 09:40 PM   #19
Mr Speirs
Mr Speirs's Avatar
Mythbusters did this.
You get less wet when you run.
But then again only up until a point. Once you are totally wet it doesn't matter either way.
Old 06-12-11, 09:42 PM   #20
MisterTommyH
I'd agree and say 0.1 degrees. Is this science day?
