Old 11-02-12, 11:41 PM   #11
myfirstsv
Default Re: Polishing fork lowers
Polishing mop, scouring pad for the tough bits and then Autosol. It helps to have an IPod to give you something to listen to while you rub away for many, many hours.
And the more you rub the better they get. I speak as someone who has no fingerprints left. But the forks are the DBs so it was worth it.
Old 12-02-12, 12:07 AM   #12
Originally Posted by muddydude View Post
How did u dress ya calipers?im going to clearcoat my forks n wheels nxt week as road salt is getting
Me shares in autosol lol. even done my 2 minimoto frames
Search threads by husky03 he had caliper refurbs down to an art. The dressing was on the inner faces and joining point on the curvy caliper
Old 12-02-12, 03:57 PM   #13
Red Herring
Red Herring's Avatar
It was a while ago since I last did a set but when I did I used an orbital sander to get rid of all the casting marks, then a bit of wet and dry, and then one of those polishing kits that has three mops used with an electric drill. Coarse first, then medium, then a final buff. Ended up with a mirror finish that almost looked as if they have been chromed, but a word of warning....they're a devil to keep clean afterwards!
Old 12-02-12, 09:20 PM   #14
Red ones
Red ones's Avatar
Default Re: Polishing fork lowers?
I used a random orbit sander with a polishing pad and anusol.
Or was it autosol?
Old 12-02-12, 09:32 PM   #15
Or was it autosol?
got piles??
Old 13-02-12, 01:22 PM   #16
Jayneflakes
Jayneflakes's Avatar
Same here, hours with the wet and dry and then hours more with the polishing mop. I did have to use Anusol after!
Top tip, take a cushion to the garage!
Jayne you're a Pussy Magnet
Old 13-02-12, 04:02 PM   #17
davepreston
seriously
get a grip man, who gives a monkeys if its shiney you supposed to ride the bloody thing
whats next you getting a vazzale
walks away shaking head
Old 13-02-12, 04:36 PM   #18
Originally Posted by davepreston View Post
seriously
Beats bending them!!
*Runs in other direction*
Old 13-02-12, 05:14 PM   #19
Before attacking them with any sort of abrasive stuff, which will leave marks on them.....strip the laquer off with Nitromorse, or as I preferred as it was more effective, Blackfriars, it doesn't run and is slef nuetralising.
Once you have got rid of the laquer, and have washed your forks, it will give you a better idea of how heavy a grade of wet n dry to use...or whatever you fancy using.
I am offended,you didn't ask me!
And no clear coat after, because it'll only happen again, waste of time IMO, better to spend five minutes polishing them up than all the faff of stripping again.
Old 13-02-12, 06:42 PM   #20
haha
Forgot you've done yours. I very much doubt that mine are coated (unless they're done at the factory).
Mine are just dulled with a bit of well ground in crap which may shift with bar keepers
Fork tops cleaning/polishing? SIII SV Talk, Tuning & Tweaking 1 27-12-11 04:11 PM
Fork polishing MacDaddySV SV Talk, Tuning & Tweaking 11 26-02-09 06:13 PM
Fork lowers nicollow SV Talk, Tuning & Tweaking 1 13-08-06 11:49 AM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
my fork lowers are looking shabby dazzaone SV Talk, Tuning & Tweaking 5 06-04-05 09:39 AM
