Old 21-02-12, 02:02 PM   #11
Default Re: CCT rattle, is this normal or not?
Originally Posted by Taipan View Post
. Am I missing something obvious here?
Yes
Just copy and paste the part number into Robinson's search bar
Old 21-02-12, 03:07 PM   #12
Taipan
Taipan's Avatar
Lol, cheers!
Old 21-02-12, 03:20 PM   #13
Taipan
Taipan's Avatar
K3 CCT is only EUR 49.50 from CMSNL in the Netherlands. But with bolt sping and gasket is £61 delivered. Or £51 delivered from powersportplus in the states!
Old 21-02-12, 03:41 PM   #14
Taipan
Taipan's Avatar
According to the Alpha Sports fiche its 12830-17G00, may have been updated.
I got one new off Ebay for £10
Pity when Sv was bike of the month a few years ago they were selling them for £35
£70 at Robinsos Foundry
Shame the one from a DL VStrom 650 doesn't fit as that's BOTM at present! But for anyone else the part number is
12830-27G00 CAMCHAIN ADJUSTER, FRONT TENSIONER 1 £73.39 £36.88 Total order £36.88
http://www.suzuki-gb.co.uk/bikeofthe...2012/february/
Old 22-02-12, 01:37 PM   #15
If you want to be sure then pull front cam cover and check chain for slack.
If you swap them front-rear it will shut up for a minute or so, you don't hear rear because it gets full of oil.
Old 12-03-12, 10:27 AM   #16
Taipan
Taipan's Avatar
Well I fitted a s/hand K3 one and it did indeed cure the rattle.
Old 12-03-12, 10:42 AM   #17
muzikill
muzikill's Avatar
How many miles was on the bike btw? It would be nice to know what the limit would be on expecting to replace this part.
Old 12-03-12, 07:01 PM   #18
Taipan
Taipan's Avatar
28k. There is still some rattle but its lessened it by about 75%. I only replaced the front cyclinder one too. Might have shut it up completely had I have done both?
YC2 rattle can? HoL SV Talk, Tuning & Tweaking 7 28-12-11 08:28 PM
Rattle from clutch? metalangel Bikes - Talk & Issues 7 19-09-09 12:51 PM
New K8 rattle mustnt grumble SV Talk, Tuning & Tweaking 15 13-04-09 09:55 AM
What's this rattle northwind SV Talk, Tuning & Tweaking 10 07-05-08 06:42 PM
Rattle? barmy.biker SV Talk, Tuning & Tweaking 8 30-11-07 07:49 AM
