#11 |
before you go slicing anything try pealing it off first. if its been painted on backing or chip paper then tiz a nightmare but most wallpapers have a top and bottom paper and usually separate easily leaving the bottom (backing) paper. i also tend to use a wet sponge and let the water soak in a bit before using a steamer.
#12 | |
This. But it depends on the brand of wallpaper. Cheaper paintable papers are not multi-layer but stuff like, say, Super Fresco is peelable as long as you can get a corner loose. Several layers of paint though make peeling difficult. Do NOT make it a competition among many hands or you will end up with no plaster!! If you do go down this route just make sure you have Mambo Number 5 playing in the background and give everyone kitchen utensils as scrapers.
We are the Goon Squad and we're coming to town, BEEP BEEP! |
#13 |
Well progress has been much better today, looks like I picked the hardest wall to start! Under the paper though there's two signatures and '59 and '66 so don't think it's been done in a while lol
#14 |
Our whole house was like that when we moved in I just used a wire brush on the walls then a steamer, once you got it started I found that it was coming off quite quickly. overall it was a bit of a hassle but well worth it...
Innuendo - it's great when you get it. sv650s (gone) gsx-r600 (gone) Street R675 (now living in Inbhir Nis ) |
#15 |
Sweet. Oddly enough I always leave a note and sign the wall when I hang paper too. My dad also found "Mick and Jack built this bungalow 1967" in the concrete of the chiney breast in his loft.
#16 |
My dad always did the same - I always put my name and the date underneath.
#17 |
If you're struggling with a DIY steamer then hire one, it'll cost alomst the same as buying a DIY one but it'll be a lot more manly. Made short work of some difficult stuff I had.
Re: wallpaper hanging | Whyte25 | Guildford Massive | 3 | 10-01-11 11:06 AM |
SV650 Wallpaper | Sony Tony | Photos | 58 | 06-01-09 01:02 AM |
My new wallpaper... | Troy | Idle Banter | 4 | 06-08-08 05:46 AM |
Icecream run wallpaper UPDATED | stuartyboy | SV Ecosse | 33 | 18-11-06 12:45 AM |
Stripping off | rubberduckofdeath | Bikes - Talk & Issues | 3 | 30-06-05 06:16 PM |
