Old 02-03-12, 10:55 AM   #11
Sir Trev
Sir Trev's Avatar
Default Re: how to make a sv650 feel new?
Go and see Spannerman for one of his full service specials? My curvy ran like clockwork after he'd worked his magic on it.
Old 02-03-12, 02:04 PM   #12
kiggles
any one done front fork oil change before? is it an easy DIY job and any speciall tools needed and oil spec?
Old 02-03-12, 02:09 PM   #13
Hornstar
I found it pretty easy. Just make sure you loosen the top nut on the fork whilst they are on the bike. Makes it so much easier than when they are off the bike.
Sent from my GT-I9100 using Tapatalk
Old 02-03-12, 04:35 PM   #14
mikerj
Default Re: how to make a sv650 feel new???
Blueprint the engine/full service
A full service certainly, but blueprinting an engine is an enormous amount of work for minimal gain. It's only ever worthwhile if you are trying to extract the last 0.1bhp in a restricted race series.
If it's the original, at 30k miles the rear damper on an SV will be knackered. The linkages on the rear may be worn if they've not been looked after. The fork oil will be beyond nasty if it's never been changed. Fixing these will make a big difference, as will a set of fresh tyres if they are particularly flat.
Control cables will probably be worn, especially the clutch. A new cable and cleaning/greasing the clutch mechanism will give you back a nice light clutch.
When was the last time the brakes had a thorough overhaul? If the piston or sliders are sticky then the brakes feel terrible. New fluid and maybe new brake lines would be an idea if not already done.
Old 02-03-12, 04:43 PM   #15
-Ralph-
Fork oil your looking at around a tenner for a litre. Which is enough for both forks as far as I'm aware.
Unfortunately not. 568 ml per fork if I remember correctly.
Old 02-03-12, 05:08 PM   #16
Dave20046
Dave20046's Avatar
I'm assuming someone's mentioned overhauling the brakes if not been done very recently
There's a guide in the FAQs of either this site or svrider which explains both the proper method and the shortcut with a syringe.
And yes it's easy, just need a jack, spanners/sockets etc.
How cool can your kids make you feel? DJFridge Idle Banter 4 28-06-11 06:31 AM
How does your job make you feel? Alpinestarhero Idle Banter 68 05-03-10 11:38 PM
Songs that make you feel old. Richie Idle Banter 3 26-08-09 11:23 AM
Photo's that make you feel old! Bluepete Photos 22 18-07-09 09:01 PM
Some things garunteed to make your SV feel better. Alpinestarhero SV Talk, Tuning & Tweaking 12 05-03-09 11:10 AM
