#11 |
deffo interested if they are cheap enough
#12 | |
When I did mine I measured the idle ignition before/after and saw a nominal 2deg shift, but you might be able to get it a touch more depending on how far you want to shift the pick-up. As per the photo the pick-up body sits in a recess in the cover, you could fettle some of the cover away to move it a little further, the slot would probably break out of the end of the tab so a slightly larger dia washer or even a stepped item made to clamp it if the tab ends get too near the bolt centreline (if you see what I mean).
#13 |
Hi All
OK I'm having a small batch of 15 keys made at the moment, due to the small qty it will be a couple of weeks before they arrive with me. See the For Sale section for more details Jim |
#14 |
Some nice info on here about what the advance key helped with
Look at the bottom end torque after the key was fitted http://www.johnnyrod.co.uk/sv650.html Jim |
#15 | |
360 degree aircraft | phi-dan | Photos | 5 | 18-07-11 06:26 PM |
degree, quickest to do | davepreston | Idle Banter | 40 | 02-02-11 12:57 PM |
4 degree ignition advance does it work on a K6? | Jackie_Black | SV Talk, Tuning & Tweaking | 25 | 23-07-08 10:35 PM |
Who has a degree and doesn't use for their job? | metalmonkey | Idle Banter | 117 | 10-12-07 09:29 AM |
wanted: dimensions of the offset timing key mod | r4ce_e3nd | SV Talk, Tuning & Tweaking | 2 | 22-03-06 05:11 PM |
