Old 20-03-12, 10:52 PM   #11
dkid
Default Re: Short levers
These are extendable. Can be four or two finger operated. Bit more pricey than others but gives you the option to play with the style that suits you best.
http://www.ebay.co.uk/itm/Ext-Clutch...ht_5213wt_1139
Old 20-03-12, 11:14 PM   #12
mpsricky
i see u have a set of cnc adjustable levers, have you got a set of these?? Just curious like to have recommendation of stuff when buying!!
Old 20-03-12, 11:21 PM   #13
dkid
No, mine are adjustable but not extendable. Saw these in another thread in hardware section.
As far as recommending the ones I do have, I'd say they're great. Fitted in minutes and adjusted to suit my grab very easily. Quality very good and a big improvement looks wise.
Old 21-03-12, 09:21 AM   #14
SamN
Didn't think about ordering from hong kong! If they're as good as you guys say they are I might put an order in later
Old 21-03-12, 10:01 AM   #15
Reeder
I have cheapy levers that are black with 'red' adjusters (slightly off red really but I'm not complaining) and both are stubby. Two finger braking is completely fine but I find I tend to use three fingers for the clutch. I'm used to it now and tbh I never actually used my bike before I put the levers on I don't think.
Old 21-03-12, 10:02 AM   #16
AZZ3R
http://www.ebay.co.uk/itm/Brake-Clut...item4153f9f145
I bought them, came 5days later. Easy to fit & just as good as OEM. & Look great. £24. I've been asked a few times are they Pazzo.
The short clutch lever feels heavy at first but after about a day it's fine. I won't go back to OEM levers after owning these.
Old 21-03-12, 10:55 AM   #17
SamN
Cheers guys, I will order some of those with the black lever and blue adjuster
Short brake and clutch levers? sniff SV Talk, Tuning & Tweaking 14 06-05-10 10:38 PM
Curvy Carbs, clutch levers and brake levers 21QUEST For Sale - SV's and SV related items 2 03-03-10 11:04 AM
had a bit of fun on a short break. Quiff Wichard Photos 23 22-01-09 07:22 PM
A short vid from the second leg of the AR northwind 2007 Annual Rideout 9 02-07-07 08:57 PM
Rene - Short can vroooOOOM Exhausts 4 08-08-04 06:28 PM
