Old 28-06-12, 01:03 PM   #11
YaelD
Just a quickie on those and their ilk - ie. Adjustable levers that bring the lever closer to the bar ... I found they didn't work! On the advice of my mechanic, I changed my clutch cable and oiled it mercilessly and that did help a whole heap.
Additionally, I invested in EZ pull levers - supposedly brings the force of the actual lever pull down to 7lbs per <insert some measure>. That's beyond my level of technical, but it does mean I can single finger my clutch in London traffic quite happily (though two fingers better) - girl hands.
Sent from my GT-I9100 using Tapatalk 2
Old 28-06-12, 01:05 PM   #12
650
650's Avatar
Default Re: Lever adjustment to releive wrist pain?
Can you elaborate on 'didn't work' for me? Don't wanna waste my money if I can avoid it haha!
650 is offline   Reply With Quote
Old 28-06-12, 02:03 PM   #13
YaelD
Sure. The set I had, did bring the levers closer to the handlebars but, and I'm guessing at the logic here, I still had to apply the same pressure to activate the clutch and/or brake, so the issues I was having with sore hands, arms, shoulders and neck, remained. Might even have gotten worse.
When I changed the clutch cable itself and drenched it in oil, this did make a significant difference. I had already purchased my new lever, so I'm not sure whether the cable replacement would've been enough, in and of itself.
Changing the throttle cable looks like a more convoluted process, but I may have to bite the bullet if the £7 Cramp Buster thingy doesn't work.
Old 28-06-12, 02:07 PM   #14
NTECUK
NTECUK's Avatar
Check cable and actuator .
Mine needed a good clean out and setting up .
Easy after that. i did get a basic flashy levers though .
Hey it looked good .ok .
Fasion victim
Old 28-06-12, 02:12 PM   #15
MartinT
I bought a pair of banditmania raised clip-ons years ago in a last ditch attempt to make the bike more rideable for me, I wasn't expecting much from 50mm but as it turned out they made the world of difference and I'm still riding the SV today.
I do think threads like this are great for info. but do highlight that what works for one person will not necessarily work for another.
Old 29-06-12, 07:54 AM   #16
johnnyrod
johnnyrod's Avatar
Default Re: Lever adjustment to relieve wrist pain?
I read something on svrider i think about changing the clutch cable for one wihtout the 90 degree metal bend at the lever end. I don't have aproblem with the weight of pull (wouldn't want it to be any more though) but I do find the action of the clutch a lot less predictable than I would expect, and I think it's down to the cable action not being great (yes all adjsuted up etc. and not the first bike I've ridden with this type of cutch lifter). Must get thumb out and try...
Old 29-06-12, 07:59 AM   #17
NTECUK
NTECUK's Avatar
Man up and get some strength is the other option.
Ps
Don't get a 'prilia V as its heavyer and hydraulic .
Old 29-06-12, 10:40 AM   #18
Jayneflakes
Jayneflakes's Avatar
This is a very interesting point, I still find that after a few hours in the saddle, my hands are tired and ache, but I have always put this down to the knackeredness of my hands due to too much climbing in my twenties.
For me, the biggest issue I had was reach, trying to reach standard levers caused pain and fitting adjustable reach ones meant that I can put that lever closer to the bar. As I said, I discovered this by accident and thus have never given any thought to the strength of pull needed on the lever. However, I use a V-strom clutch cable on my bar conversion and keep it well adjusted and lubricated. A sticky cable is not great for either hand or clutch action. As for front brake, I have braided lines and lever action is so silky soft and brake action so firm that I can really feel the difference.
Jayne you're a Pussy Magnet
Old 29-06-12, 11:59 AM   #19
johnnyrod
johnnyrod's Avatar
Back tot he OP, have you tried adjusting the angle of the lever? If it's pointing up too much then this makes your hand ache quicker. Also remember if you're changing gear you don't need to pull it all the way back to the bar, a quick dab will take enough weight off the gearbox for a change.
Old 30-06-12, 09:09 PM   #20
Kenzie
Kenzie's Avatar
I haven't yet, but I have ridden more over the last few days and tbh I think I don't ride enough to get used to it. I can go weeks without getting on the bike so maybe that's what doing it. Simply gripping the tank more has helped
Gear lever adjustment? heros Bikes - Talk & Issues 4 10-02-09 09:13 PM
Gear lever adjustment? Orpheus SV Talk, Tuning & Tweaking 2 13-07-08 06:36 PM
Brake lever adjustment jamesw1024 SV Talk, Tuning & Tweaking 4 31-07-07 03:01 PM
Shift lever adjustment Heafer SV Talk, Tuning & Tweaking 5 15-07-06 11:35 PM
Clutch Lever Adjustment MarkyBoy SV Talk, Tuning & Tweaking 6 03-08-05 12:52 PM
