#11 |
those bars bring them up higher and closer to you (as they rise the forks point towards you so the bars go up and towards you) and you can change them to be wider or narrow to suit you better.
#12 | |
#13 |
If you were closer agy I'd offer you to have a spin on mine as i had similar issues to you.
I've fitted a gel seat (best £100 ever) and those clips on's and it's made it the perfect daily for me. Last edited by Fozzy; 29-06-12 at 08:06 PM. Reason: typo |
#14 |
I have the same as those (cost me £114 new as those weren't on Ebay at the time)
I have raised mine about 2 cm over the previous clipon's height but that 2cm is higher up and closer to me if you know what I mean. They aren't +50mm they are +40mm (over std clipons) the ebay's is wrong. They are slightly flatter to (less drop) that std clipons. |
#15 |
good stuff. i can wait with buying the seat until i'm feeling rich; just live with the pain in the a**e so to speak for a bit longer but the neck pain is not tolerable.
I will bid for the ones on ebay. Damn I hope I win them! I think they normally cost £200. my local garage said it will be an hours labour if I provide the kit so only another 40 squid on top. it was my local mechanic who said the full bar will hit the fairings. he's got one but his sv is naked |
#16 |
Agy they are £114 see here..
Clicky as you can see they are + 4cm you would need the 41mm versions. It's easy to fit and if you have a local Org member with some time I'm sure they could help you fit them for tea and bacon sandwich is the normal costs.. ![]() |
#17 |
Agy here is a comfort kit from a person who sells them, while his parts look ok he has a rep on here for being slow to post.
comfort kit full bars |
#18 |
#19 |
![]() Last edited by Fozzy; 29-06-12 at 08:18 PM. |
#20 |
So looks like def need new brake lines then?
How much better is the comfort kit to the raised clip ons? |
Improving Curvy suspension? | big jc | SV Talk, Tuning & Tweaking | 11 | 06-05-12 12:33 PM |
Improving comfort? | Rowlandz | SV Talk, Tuning & Tweaking | 0 | 03-05-11 10:47 PM |
Improving standard suspension? | Kat1986 | SV Talk, Tuning & Tweaking | 10 | 08-02-10 07:45 PM |
Improving SV peformance | Messie | Idle Banter | 6 | 10-02-08 10:03 AM |
Improving driving skills | Rog | Idle Banter | 28 | 30-08-07 08:11 AM |
