Old 25-07-12, 02:38 PM   #11
Draconis
Default Re: Curvy rear cylinder cuts out.
I am based in bolton lancashire.
I split the carbs up. I have a spare set and I chose the best rear carb, the one with the least worn needle jet. It also has a DynoJet kit fitted so I had to reuse the needle, I will re-check this for any marks at weekend.
Old 25-07-12, 04:01 PM   #12
jambo
jambo's Avatar
Simplify the approach.
You have a specific problem, try to find out what's up. Do you know someone else with an SV in Lancashire?
Don't mess about separating carbs, just shunt the whole lot in, then you can break down each section when you know that that assembly made a difference. When a friend had a similar problem we'd substitute whole systems across until we found it.
Carbs
Both Coils & HT leads
ICU
etc, turned out in his case the loom itself was at fault. We never could find a problem with it when cold, but we dropped one from another bike on and the problem went away.
Jambo
Old 26-07-12, 04:28 PM   #13
Draconis
I have split the loom to check for breaks but not found any, I am going to check the ICU connectors this weekend. The coil connections are ok,
the feed wire is ok, the ICU conns are the only ones left to check.
need small screw driver to remove them from the connector block.
Old 31-07-12, 03:10 PM   #14
Draconis
Ignition OK, looks like the rear carb is dumping fuel into the cylinder.
Discovered fuel dripping from exhaust connector when bike ticking over.
(Welded connector must be cracked internally)
Old 31-07-12, 05:10 PM   #15
read this thread, similar problem to yours
http://forums.sv650.org/showthread.php?t=181591
Old 01-08-12, 12:44 PM   #16
Draconis
Thanks Maviczap will check the fuel pump gasket.
Old 01-08-12, 04:06 PM   #17
Destruktor77
My rear cyclinder was half firing, noticalble when riding, got worse when you stopped/slowed down. Turns out the rear carbs was leaking round the bowl... Not as obvious as you think because the heat makes it evaporate quickly. Just something to check.
Old 02-08-12, 10:42 AM   #18
Draconis
Checked the fuel pump. got a mouth full of petrol. diaphragm leaking, allowing fuel into
the rear inlet tract problem solved at last.
Rear Master Cylinder: Curvy/Pointy BillyC SV Talk, Tuning & Tweaking 22 26-08-13 09:27 AM
Curvy won't idle reliably, cuts out. phatwheels SV Talk, Tuning & Tweaking 19 29-05-12 08:43 PM
Curvy rear cylinder not running. benparker SV Talk, Tuning & Tweaking 8 15-04-12 11:12 AM
TDC on the rear cylinder? 5hort5 SV Talk, Tuning & Tweaking 9 01-01-10 03:25 AM
Curvy Rear Cylinder Exhaust Stub trudd Stuff Wanted 2 03-08-09 12:02 PM
