Old 13-08-12, 10:00 PM   #11
adds
Default Re: Zx6r shock fitting curvy
You my friend are a god damn genius!!!
Old 14-08-12, 01:22 PM   #12
mister c
mister c's Avatar
Default Re: Zx6r shock fitting - Curvy.
Well, it's a while since I did that, but, if I did it again I would use a Triumph 675 Daytona gel battery, they are tiny & work fine on the SV (as I found out when I fitted the 675 rear end).
Fitting a ZX6 or 10 rear shock will make you realise just how soft the SV suspension is. I noticed the difference just pushing the bike outside to have a ride.
You will think that the front is soft then & you will want to stiffen that up too
Old 15-08-12, 08:08 AM   #13
adds
My front end is cack anyway. Keeps bottoming out do they will be coming off straight away for a rebuild with heavier oil.
Old 15-08-12, 09:49 AM   #14
Lawman
I fitted the same shock this week. I've decided to relocate the battery all together alongside the front cylinder. I might even go the whole hog and buy a Shorai. It will need a battery holder fabricating, this is for a track bike.
Another solution (my road option) might be to locate the battery on its side in the rear compartment and making some new battery leads up a little longer. Parts for leads are readily available on ebay or from places such as http://www.vehicle-wiring-products.eu. You will only need a lead to earth and one to the starter solenoid. In this way you can use your original battery.
Old 15-08-12, 10:00 AM   #15
jambo
jambo's Avatar
I put a 2010 ZX6R shock in my curvy, about the worst place you could have a reservoir...
I cut the battery box to give space for the shock.
I cut the battery holder section off the tank pivot.
I added a small plastic box spacer ~70mm high, and rested the battery on top of that, with the fuse box moved into the left side tail panel.
I also had to take some material off the rider's seat mounting lug as at full compression, this was touching the shock.
Works well though...
Jambo
Fitting a ZX10 06 shock to a Curvy Berlin SV Talk, Tuning & Tweaking 30 16-04-11 01:52 PM
ZX6R B1 2003 rear shock - fits curvy (with some mods!) stuballs For Sale - SV's and SV related items 5 13-11-09 12:57 PM
Zx6r Shock SAMMY650 For Sale - SV's and SV related items 7 08-07-08 09:37 PM
zx6r 2007 shock for a curvy? Ey Uup SV Talk, Tuning & Tweaking 4 01-07-08 10:22 AM
Won an 03/04 ZX6R shock 4 my curvy 2nite :) SVmonkey SV Talk, Tuning & Tweaking 9 21-03-07 04:03 PM
