Old 15-08-12, 08:31 PM   #11
mackemforever
Default Re: SV battery losing charge when not in use.
Originally Posted by Owenski View Post
Battery from a pointy is fine.
When you're hitting that starter button and getting the click. Have you noticed if the dash lights appear dim or not before and or after hitting the button.
If they appear fine then the way the bike is running after being bumped and starting again whilst still warm supports a starter motor fault.
Get a mate to hit the outside of the starter motor with a hammer while you hit the starter button. If it spins up and fires into life then you've got a knackered starter motor.
If that doesn't work, hit your mate with said hammer. It Won't fix the bike but it'll cheer you up.
Another possibility is the starter relay itself, easiest way to check that tough is to swap it with another.
Thanks for this suggestion. I held down the starter button, gave the motor a bit of a tap and it started straight up.
So, new starter motor ordered (£15 from a local breakers yard) and in the mean time I've packed a hammer under my seat for when it won't start!
Old 16-08-12, 09:37 AM   #12
m`baubz
Default Re: SV losing charge when not in use
Originally Posted by Coder View Post
I have same issue with my curvy. New reg and bat, leaks voltage when switched off. Multimeter gives 12.5v when tested on positive bat terminal and frame. Driving me nuts.
that's what it's supposed to show. you check for leaks by measuring amps between a terminal and its respactive lead (with it being disconnected from the battery, of course).
New battery - charge it or not? ork56 SV Talk, Tuning & Tweaking 10 11-03-11 05:29 PM
And the best way to charge a battery is. . . rowdy Idle Banter 6 25-01-10 12:33 PM
First charge of a new battery. JediGoat Bikes - Talk & Issues 40 13-12-09 11:51 AM
new battery - how to charge for first time ? Warren SV Talk, Tuning & Tweaking 18 03-12-07 09:43 PM
Do I need to charge my battery? M65 SV Talk, Tuning & Tweaking 6 15-07-05 11:20 AM
