Old 21-09-12, 03:04 PM   #11
Swin
Swin's Avatar
Default Re: daughters car service. What are they going to find
Originally Posted by Fallout View Post
Find a good garage and stick with it! Much easier said than done. {snip}
Can't agree with this more, we have used the same garage for 15 years now, fantastic service and great guys, I would thoroughly recommend Burnt Mill Motors in Harlow to anyone
Riding a V-strom, well it has an Sv engine, don't it
Swin is offline   Reply With Quote
Old 21-09-12, 03:09 PM   #12
shonadoll
I went to kwikfit as my lights weren't working. It was a fuse. They spent fifteen minutes working it out, changed it, it all worked, and then refused payment. I gave the guy a tenner for a pint and he refused, then eventually took it.
Old 21-09-12, 03:26 PM   #13
NTECUK
NTECUK's Avatar
Its more down to the individuals ,than the name over the door at the end of day.
Old 21-09-12, 04:01 PM   #14
ClunkintheUK
Definitely true. Had really good service from a kwikfit in Bristol.
Old 21-09-12, 05:06 PM   #15
They quoted my Grandma £800 to replace parts of the exhaust on her Ka.
Funnily enough it was all sorted and through the MOT for <£50.
Hope they sh*t hedgehogs.
I think it would be a bit of a laugh to find out where the manager lives and nick his catalyser or something for a bit of ironic justice.
Old 21-09-12, 07:41 PM   #16
muzikill
muzikill's Avatar
I never trust 'quick' places. A honest down to earth garage is what you want. Based on recommendations not covenience.
Old 21-09-12, 08:19 PM   #17
suzukigt380paul
i know ive said it before,but the chap i take my motor to is a x main dealer mechanic who has gone self employed,have known him for 35 years(but may only see him a couple times a year), and he is a biker as well,but he doesn't charge more then £12 a hour.
could be "great rates or mates rates" as that add goes,but he only charges what the parts cost and doesn't inflate the prices,and isnt worried if i supply the parts,and i cant fault the chap
Old 22-09-12, 11:46 AM   #18
timwilky
timwilky's Avatar
Well, as I suspected it went through with a clean bill of health.
He did say to her on leaving to tell your dad to keep an eye on the brakes.
Not Grumpy, opinionated.
Should daughters be drowned at birth? timwilky Idle Banter 34 22-05-12 11:01 PM
My Daughters BMW MINI for sale stressed_myke Idle Banter 0 02-05-12 04:37 PM
Where can I find clutch housing bolts? - Cant find any mikeSV SV Talk, Tuning & Tweaking 2 24-03-08 12:30 PM
