Old 23-09-12, 06:26 PM   #11
Default Re: Sv minitwin
Originally Posted by Winder View Post
All SV suspension is budget mate. You couldn't race with stock suspension, no chance.
Look at the rules on the minitwin site and you'll see this class was designed to keep things competitive so it's not the bloke with the biggest wallet that wins.
You could if you were Dani Pedrosa's weight!!
Allow a minimum of £200 for the suspension and around the same for bodywork
A race belly pan of around 6l is needed on a SV (oil and coolant system) and that is a ACU requirement and can't be avoided.
Also spend £40 on a lockwire kit and some good fine metal or HSS drill bits
Old 23-09-12, 06:28 PM   #12
flymo
flymo's Avatar
Ah yes , thats how it first appears. The engine has a limited amount of budget sucking potential, but its amazing just how much you still spend on an SV.
Old 23-09-12, 06:32 PM   #13
Yep!!
Ask Berlin that question
http://forums.sv650.org/showthread.php?t=153136
Old 23-09-12, 06:34 PM   #14
SVJC
Andrewsmith cheers for the advice. Where is the best place to get a race belly pan? That ACU handbook is a long read. Im deciding between 2 race fairings at the mo.
Sent from my HTC Desire HD A9191
Old 23-09-12, 06:41 PM   #15
Pointy, ARD's are one of the good ones
http://www.ardracing.com/suzukisv650.html#AxfQP0TqXvsW
Old 23-09-12, 06:41 PM   #16
flymo
flymo's Avatar
No need, I built and raced one myself. No sponsorship so had to fund everything myself.
Old 23-09-12, 07:12 PM   #17
SVJC
flymo how long did it take you to build your bike?
Old 23-09-12, 07:17 PM   #18
flymo
flymo's Avatar
I think I bought it in the January and my first race that season was towards the end of March.
It really depends on how much work you do, I bought mine as a naked road bike that wasnt running. It needed a full strip and service to get it top notch. If you are starting from something altogether more road worthy then it may not take so long.
Start by making a list of the things that you MUST do to race it, there will be plenty of additional things that you might like to do but they are extras.
If you can find a race ready bike it will save you plenty of work but that totally depends on your budget.
Alternatively, if you want to pay me to race prep a bike for you I'm up for it.
Old 23-09-12, 07:26 PM   #19
SVJC
so not to long considering the work you had to put in to getting it up and running.
Well at the mo this where i am i got a k7, fully faired, braided hoses, hyperpro front springs, nitron rear shock and a scorpion end can. This is my road bike but after weighing up my 2 options after i was told i would get bugger all for the pointy as she stands at 30k on the clock i think this is my best option.
Thanks for the offer tho flymo i will keep that in mind
Old 23-09-12, 07:31 PM   #20
flymo
flymo's Avatar
just remember there are plenty of things that you 'could' do but really dont need to. Stick to the essentials to get started.
Catch tray for fluids, a race fairing normally has this built in. Rear sprocket guard (sometimes called a shark fin) needs to be fitted. Braided hoses (done), lockwire the oil filler cap, replace the coolant with clean water (watch out for freezing during winter, I used to leave it filled with coolant until just before the season start then switch to water). Remove any road lighting or glass parts.
The remainder is just about road worthiness, everything working and in good order.
Somewhere to fit your race numbers and you're good to go.
Everything else is performance upgrades.
Building a Minitwin darren g Mini-Twins 9 04-02-13 11:06 PM
Building a dog pen/run hongman Idle Banter 12 04-04-12 07:12 AM
Building a minitwin mbeets Mini-Twins 23 14-12-11 04:47 PM
building a pc aarond Idle Banter 14 13-11-09 08:53 PM
Building a Minitwin race parts wanted toot Stuff Wanted 0 21-08-09 05:05 PM
