Old 02-10-12, 09:00 PM   #11
DJ123
DJ123's Avatar
Default Re: 100% acetone in sv650 curvy
Originally Posted by Joe Marcon View Post
Well not gunna lie it runs smoother . Pulls abit better . But only using for this one tank .
The placebo effect
BMW F800ST
Old 02-10-12, 09:04 PM   #12
Joe Marcon
It could be a mentally, thinking its better lol .
But i genuinly think its better
Old 02-10-12, 09:38 PM   #13
embee
embee's Avatar
Rubber used for gasoline applications are nearly always nitrile (NBR) or fluorocarbon (FPM) e.g. viton, neither of which are suitable for acetone according to the compatibility chart here for example (rated as 4 on a 1-4 scale, 1=satisfactory, 4=unsatisfactory)
Old 02-10-12, 09:44 PM   #14
sv_rory
true! had to learn all of that on my theory for my painting
Old 02-10-12, 10:10 PM   #15
Joe Marcon
Ar well its running fine . Need new chain and sprockets fitted now
Old 03-10-12, 12:12 AM   #16
Tomor
Tomor's Avatar
I use it on long journeys, but honestly, its more hassle than it worth. then you forget to put it in a tank and you have to store it on the bike. It works for long trips, not noticeable on short journeys, and i do find it increases MPG, but too much hassle to do it regularly
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 03-10-12, 08:52 AM   #17
johnnyrod
johnnyrod's Avatar
If you must put something in then a shot of meths or IPA (aka Wynns Dry Fuel) is better, octane number will be increased a bit, but really it's pointless in a stock engine (i.e. stock compression ratio). Any of these things (including acetone) will make more acidic by-products in the exhaust gases, plus as said above, acetone is a fairly strong solvent so will attack rubbers (you can't just label an organic solvent as "corrosive", it's like saying forest camouflage will work in the arctic and vice versa). Engine "cleaners" typically are fairly involatile e.g. Redex, as it's fetches up on the back of the inlet valves when the fuel evaporates then washes the gunk off. There are some cleaning jobs in carbs etc. for additives but again solvents aren't going to do much there.
Old 03-10-12, 08:59 AM   #18
Dicky Ticker
And here is me thinking he was dry cleaning his bike------silly me
Old 03-10-12, 12:04 PM   #19
Scylla
Default Re: 100% acetone in sv650 curvy?
NO NO NO NO NO NO NO NO!
This "Engine cleaning" stuff is bull****. This is a light solvent, relative to compounds found in petrol so it will strip any accumulations inside the engine. guess where that gunk goes? through the rest of the engine!
Carry a camera and a fire extinguisher with you on future rides.
Old 03-10-12, 12:22 PM   #20
Joe Marcon
A guy got a normal engine and an engine that had used acetone . He cut them in half and the acetone engine was much cleaner and better all rounder
My 2nd SV650 curvy richspace Idle Banter 4 08-03-09 01:04 PM
SV650 Curvy carsounds_dan Stuff Wanted 4 04-04-08 07:21 PM
sv650 curvy ICAEW For Sale - SV's and SV related items 0 03-03-08 10:28 AM
where to buy acetone (or other fiberglass resin solvent/cleaner)? weazelz SV Talk, Tuning & Tweaking 6 08-05-07 09:09 AM
Best can for 99 curvy sv650?? 5v5 rider SV Talk, Tuning & Tweaking 14 09-05-06 04:56 PM
