Old 14-06-13, 09:54 PM   #11
Default Re: Panniers rubbing on rear panels
Check your local Maplins as its been on for £8 for ages
Old 14-06-13, 10:43 PM   #12
sputnik
...and then buy it in poundland!
Old 15-06-13, 12:15 PM   #13
otaylor38
I to use that non slip rubber matting stuff. It sometimes leaves abit of a mark where its kind of stuck to the paint, but that can be wiped off and it never scratches.
I cut it to size so it can go under the pillion seat (a hole for the latch) then it cant slide off and hangs down over the side panels.
Old 15-06-13, 12:36 PM   #14
Skybaba
Default Panniers rubbing on rear panels
Originally Posted by otaylor38 View Post
......I cut it to size so it can go under the pillion seat (a hole for the latch) then it cant slide off and hangs down over the side panels.
I like that method.
Rear panels sam-bliss Stuff Wanted 3 20-05-13 05:48 PM
Rear brake rubbing on cb500 stuR Bikes - Talk & Issues 5 30-04-13 09:09 PM
Rear Side Panels HopefullySoon Stuff Wanted 5 03-05-07 01:04 PM
Rear Brake Pipe rubbing on Swingarm. david-m SV Talk, Tuning & Tweaking 6 08-08-06 04:46 PM
rear brake pads/disc rubbing will SV Talk, Tuning & Tweaking 4 02-03-06 10:19 AM
