Old 15-02-14, 06:19 AM   #11
prokartman
prokartman's Avatar
Default Re: Soft brake lever & faded top of disc
I mentioned a sticking piston due to the fact that there is an area of disc that appears not to be being touched by the pad and seeing as its on the outside of the disc it would probably be the top piston and not the lower one . Agreed that the pistons wont move out together but it will be obvious if one refused to move at all or even only marginally .
prokartman is offline   Reply With Quote
Old 15-02-14, 09:39 PM   #12
Originally Posted by prokartman View Post
I mentioned a sticking piston due to the fact that there is an area of disc that appears not to be being touched by the pad and seeing as its on the outside of the disc it would probably be the top piston and not the lower one.
No it wouldn't, both pistons are on the same side of the disc. If either piston moves the pad will contact the disc.
Old 16-02-14, 06:13 AM   #13
prokartman
prokartman's Avatar
Blonde moment on my behalf ! Yes side by side on the disc not upper and lower ., thank you Sid .
Soft lever after fitting braided lines. doofus4000 Bikes - Talk & Issues 15 13-06-13 03:54 PM
RH Footpeg Hanger, Rear Brake Lever and Clutch Lever for 2004 Naked Wanted Drumming_Animal Stuff Wanted 0 26-07-10 10:52 PM
Soft, spongey rear brake. beno987 SV Talk, Tuning & Tweaking 2 20-07-10 08:45 PM
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
