Old 06-05-14, 07:41 PM   #11
Darkzy43
Default Re: Issue with starting bike
I just checked the STPS, i can turn the nut on the sensor housing and the butterfly valves move but the bar itself seems jammed, but the only thing that seems to be causing this jam is the STPS
Old 06-05-14, 07:44 PM   #12
Darkzy43
Doesn't prime (no fuel pump noise just relay click) and the TB's don't move.
I can't of wired anything up wrong.. It's all multi-plugs haha and i kept most of the connections on the TB hooked up..
What could i possibly of wired wrong.
Is their a easy to read diagram or picture of the multi plugs that is labelled?
Old 06-05-14, 07:45 PM   #13
Darkzy43
Definately doesn't do this.. https://www.youtube.com/watch?v=2dkXIIf7U20
Old 06-05-14, 07:49 PM   #14
the STPS wont move till you turn the ignition on. mucking around with the censor will completely screw the STPS up and will need reset which is a PITA as you need a depthstop/vernier gauge.
if its not going threw the prime then something is not wired up or jammed.
Old 06-05-14, 07:52 PM   #15
Darkzy43
Hmmm, Strange.. I'll have to take a look again, The STPS plug never moved though, Was connected the whole time... I don't know what's going on.
Wiring diagram? Diagram of anysort?
Old 06-05-14, 07:55 PM   #16
you changed the engine and never unhooked the throttle bodies. thats a neat trick.
Old 06-05-14, 07:57 PM   #17
Darkzy43
Haha okay okay smarty pants :P
I mean the plugs to the STP and to the injectors themselves where there, only unplugged the wires necessary to release the TB's.
Old 06-05-14, 08:34 PM   #18
do you have a gmail account?
if so can you PM me and i'll send you a wiring diagram.
you bike is a K8 right?
Old 06-05-14, 08:51 PM   #19
Darkzy43
K5, Shoulda specified sorry.
Will PM the addy, they can't be too dis-similar.
Old 06-05-14, 09:06 PM   #20
hmmm. the twin spark is pretty much different.
i'll see if i can dig the K3 one out.
Starting Issue curvy hindle8907 Bikes - Talk & Issues 10 10-07-13 02:49 PM
Starting issue - K3. Badeye Bikes - Talk & Issues 1 17-01-12 12:47 PM
GSX starting issue keltoi Bikes - Talk & Issues 6 09-05-10 09:29 PM
starting issue AndyBrad SV Talk, Tuning & Tweaking 58 23-04-09 08:12 PM
Help - Starting issue or lack of Pingu65 Bikes - Talk & Issues 3 28-12-08 12:23 PM
