Old 30-03-16, 09:31 AM   #11
onewhosquawks
Default Re: Carb Rubber leak symptoms
New rubbers were delivered today.
Thanks for the sanity check. I'll get to this on Sunday. Will pop back in if I run into problems.
Just want this bike back on the road so she can give me my zzr back. Currently commuting on a transalp. No fun
Old 04-04-16, 08:29 AM   #12
onewhosquawks
Right so this weekend I stripped her back and had a look.
First thing - the o rings that sit betwwn the carbs and the engine popped out and were at least 5mm longer looking than they need to be - i tried freezing them to see if the shrunk back to fit but nope. So do o rings really expand that much? I've never seen that much expansion before.
Secondly - the shop I took her too must have not put coolant in after getting to the front spakplug. Old girl was dry.
And finally - I vacuum tested a lot of the tubes and the one that connects to the rear carb before it meets the engine had a poor seal.
I've ordered new o rings and hose and clips and will silicon gasket every damn thing that connects to another. I can't believe the quality of the work the garage did.
Old 04-04-16, 10:16 AM   #13
muzikill
muzikill's Avatar
Lets hope theres no damage with the coolant issue. I'd be going back and kicking up a stink and a half.
Carb fuel leak. Scythe92 SV Talk, Tuning & Tweaking 15 17-05-18 05:56 PM
Rear carb fuel leak curvy 2000 sparky4306 SV Talk, Tuning & Tweaking 6 17-04-15 02:22 PM
Curvy S rubber headlight rubber dust seal otaylor38 Stuff Wanted 1 12-03-13 10:32 PM
Withdrawal symptoms NTECUK Idle Banter 4 12-10-12 04:13 PM
Oh dear... Take these symptoms and... northwind SV Talk, Tuning & Tweaking 13 14-07-08 10:37 AM
