Old 31-08-16, 07:06 AM   #11
Default Re: curvy died and wont start now!
Sounds very much like either fuel starvation or contamination. Drain the carb float bowls, it's not easy to get a container under the carb to collect the fuel such that it might be examined, but if one drops loads and the other very little, it may give an indication of what the fault is. Early SVs are prone to water in the fuel from corroded tank drains, as the years pass the problem gets worse.
There is a fuel pump, it's on the frame rail to the right of the carbs, it rarely gives trouble though so I wouldn't start there. Testing is easy though, it's vacuum operated so does the outlet give regular doses of fuel as you turn the engine over? If yes, it's very probably fine. If no, then blow through the inlet and outlet whilst blocking the other, listen very carefully through a hose connected to the vacuum connection - any hissing and the diaphragm is holed. Rebuild parts are available aftermarket if needed, Suzuki don't supply them.
Old 31-08-16, 07:58 PM   #12
gibbzy2k1
Cheers Sid. I checked the fuel pump and it was giving doses of fuel as I turned it over. I have checked the pump and there doesn't seem to be a problem with the drain. no bubbles that I could tell in the fuel when blowing down the drain. I have also taken the tank off and nothing came out of the drain when it was swished about, which if the drain was rusted I would have expected a little fuel aleast?
I have the carbs off and there was little difference in the amount drained from either float bowls that I could tell, although I hadn't seen this post at the time so was more interested in emptying them before I spilled fuel everywhere. lol
At the moment I can't seem to undo many of the screws, they are rater tight and am more likely to round them off than undo them I think.
Old 31-08-16, 09:01 PM   #13
daktulos
daktulos's Avatar
Be careful as they're not Phillips screws - they JIS which looks very similar. I spent a fair sum of money buying the right screwdriver bits before taking them apart.
Just as I was congratulating myself for getting the right tools, the last one was seized. I ended up having to drill it (just enough to loosen the head) and replaced the lot with hex-head bolts from Halfords.
daktulos is offline   Reply With Quote
Old 01-09-16, 08:30 PM   #14
Check the tank drain isn't blocked, if it is rainwater collects in the filler well and drops into the tank when you open the cap.
another curvy wont start thread! sv_rory SV Talk, Tuning & Tweaking 11 26-09-12 01:52 PM
curvy wont start! Danny Dickinson SV Talk, Tuning & Tweaking 8 22-09-12 02:26 PM
curvy wont start. stew SV Talk, Tuning & Tweaking 11 03-01-11 06:14 PM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
