#11 |
![]() Yep. It has an auto idle, so any manual adjustment is just counter adjusted by the auto adjustment. I did look into it a lot to try and rule out problems I was having before doing the TPS adjustment... which helped a lot, so I didn't take it any further. There's some info on here about it. I think Bibio may have bought an affordable tool that wouldn't work and got a refund. The alternative was very expensive. Healtech make one I think for a few hundred £. Cheaper to get it done by a dealer.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
#12 |
yes but your trying to get the suction vacuum the same on each cylinder so any changes to engine tick over shouldnt matter. Your bike must still have the intake vac tapping connections just before each cylinder so you just connect a long length of clear plastic pipe (5 metres) with a bit of water in it between each. Then make sure the pipe is run up high and then down in a loop with the water in the bottom so that on start up any difference in intake vacuum will pull the water one way or the other. At the very least you can see if any adjustment is needed......
Harlem Shake | Runako | Idle Banter | 19 | 25-02-13 10:10 AM |
MoT shake-up planned | NewsBot | News | 0 | 16-07-12 07:50 PM |
MoT shake-up planned | NewsBot | News | 0 | 16-07-12 04:50 PM |
Front end shake | maxinc | SV Talk, Tuning & Tweaking | 4 | 12-06-11 05:36 PM |
front end shake | PaulSV | SV Talk, Tuning & Tweaking | 12 | 20-10-09 10:23 AM |
