Old 11-05-20, 06:52 AM   #11
garynortheast
garynortheast's Avatar
Default Re: 2009 SV650s
Is there a separate fuse for the fuel pump on a pointy SV? I have a curvy so not sure.
Blue Curvy S with over 111,000 miles and still going strong.
garynortheast is online now   Reply With Quote
Old 11-05-20, 11:26 AM   #12
Guamsv650
Got it running. I AM A COMPLETE IDIOT.
I SHOULD DELETE THIS THREAD LOL. Anyways this is the first sv650 I ever owned. Cant wait to get it Road worthy. I need a new chain now and front and rear brake masters. They are both locked up from sitting for 4 years
Old 11-05-20, 12:03 PM   #13
garynortheast
Well done! You're not an idiot, it's all a learning experience. So what was the problem?
Old 11-05-20, 03:29 PM   #14
Grant66
Grant66's Avatar
Originally Posted by garynortheast View Post
Incidentally, the forums native image upload doesn’t work. Upload any pictures to an image host like Flickr or imgur first then paste the BB code into your post.
Seems ok on mobile.
Sent from an S20 using Tapatalk with that kin cr4p blocked
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 11-05-20, 03:57 PM   #15
Originally Posted by Grant66 View Post
Seems ok on mobile.
That is uploading to tapacrap. The forum image hosting has been broken for years, same as avatar changes
Old 11-05-20, 04:32 PM   #16
Guamsv650
I just wired up the fuel incorrectly lol.
Now off to getting a new chain and changing both front and rear brake masters then she should be okay to ride
Old 11-05-20, 04:33 PM   #17
Adam Ef
Adam Ef's Avatar
There's a good breakers in Bristol called Landmark Bikes that often has good condition bits like brakes. I think they sell through eBay. Worth getting a kit with the sprockets in too if you're putting a new chain on.
Past:
Old 11-05-20, 06:02 PM   #18
garynortheast
I would recommend getting the callipers off and cleaning them and the pistons if it’s been stood that long. Gently take the seals out too and check the recesses for corrosion. Replace the seals if necessary and make sure the sliding calliper pins are clean and greased. Put the whole lot back together using red rubber grease. DO NOT use copper slip or moly or anything else other than RRG which is vegetable based and won’t make your seals and rubber boots disintegrate.
Old 11-05-20, 06:27 PM   #19
Grant66
Grant66's Avatar
If you need some seals I've found a couple of sets in the garage, Suzuki part number 59300-33841, which you can have for the price of postage.
Sold the bike before getting around to using them.
Old 11-05-20, 09:23 PM   #20
NEALSMO
Junior Member
Did the old pump prime and run? If it did, then you can narrow it down to an install error or bad pump out of the box.
You said it has power at the pump. Does it have ground?
NEALSMO is offline   Reply With Quote
2009(59) SV650S For Sale jamesbarton_84 For Sale - SV's and SV related items 0 26-04-14 09:53 PM
For Sale - 2009 SV650S :( DaveRushton For Sale - SV's and SV related items 19 11-04-13 10:33 PM
SV650S 2009 For Sale aaronmlyon For Sale - SV's and SV related items 0 24-10-11 07:24 PM
SV650s K8 2009 Reg for sale. RedMacgregor For Sale - SV's and SV related items 9 15-07-10 04:43 PM
2009 sv650s elkieboy For Sale - SV's and SV related items 6 15-06-10 07:14 PM
