Old 30-03-21, 04:44 PM   #11
Spiral
Spiral's Avatar
Default Re: Exhaust System Recommendation
Originally Posted by kolu View Post
Does anyone tried the Black Widow 400 mm stainless exhaust? I'm quite thinking about getting it as it seems to be the cheapest road legal replacement exhaust and I'm kind of hoping it might be just a bit louder than OEM exhaust with baffle but not obnoxious like the 225 mm oval racing only Delkevic that came with my bike...
I'm looking at one of those myself, did you get one & if so how is it ?
Did you have any jetting issues & was the sound level ok ?
Spiral is offline   Reply With Quote
Old 20-04-21, 02:42 PM   #12
600rob
Junior Member
Originally Posted by DJ123 View Post
You'll notice a better engine response with the longer can. The engine likes/needs back pressure which a stubby can just doesn't give.
Look at pipewerx too for options.
was just looking at getting a 225mm stubby?
anyone got something like this and notice a significant reduction in engine response?
to be fair im not looking for max performance so i doubt it will be too bad right?
600rob is offline   Reply With Quote
Old 20-04-21, 04:40 PM   #13
DJ123
DJ123's Avatar
you need a full size exhaust for the SV as the engine needs the back pressure. Stubby exhaust doesn't work well on these engines.
BMW F800ST
Old 20-04-21, 05:12 PM   #14
Spiral
Spiral's Avatar
With the manufacturers I've looked at the DB killer is the same one for all the cans, which is what is going to give the back pressure I'd have thought ?
Old 20-04-21, 05:27 PM   #15
DJ123
DJ123's Avatar
The volume of the can makes a difference too. The DB killer only does so much.
IIRC then standard are a 450MM can, or something like that? you can then run without a baffle if you want without much loss. Stubby cans reduce the engine performance through out the range (engine braking & roll on torque) is what was lost on my bike, before i replaced it with a normal length can.
BMW F800ST
Gen 3 Exhaust Recommendation Ljay SV Talk, Tuning & Tweaking 3 08-09-19 09:22 AM
K7 exhaust system fit K3? longeatonlad SV Talk, Tuning & Tweaking 2 06-12-14 02:58 PM
New exhaust system? granty92 Bikes - Talk & Issues 4 25-01-13 09:43 PM
M4 Exhaust system viffer For Sale - SV's and SV related items 1 27-07-10 12:46 PM
k7 exhaust system sv650nutter149 SV Talk, Tuning & Tweaking 8 17-09-07 04:37 PM
