Old 28-10-04, 10:31 PM   #11
amarko5
add the one psi at the garage
then go for a blast, a bloody good one and re take readings i have seen a 10 psi increase during the summer months.
Old 29-10-04, 09:12 AM   #12
Dirty Baz
Originally Posted by fraser01
'OI BIG NOSE'
'one more time mate, I'll take you to thi fukin' cleaners!'
Old 29-10-04, 11:17 AM   #13
splke
splke's Avatar
I think what the overweight one meant is that did you use the same pressure guage for both readings ?
As they can also differ 1 or 2 psi.
+ the forecourt ones are nearly always out.
splke is offline   Reply With Quote
Old 29-10-04, 11:24 AM   #14
jonboy
Buy a footpump, take your pressures when the tyres are cold. End of story.
Old 29-10-04, 01:10 PM   #15
Jabba
OK - I've been thinking about this over a beer at lunchtime and have come to the conclusion that you need add slightly more than 1psi's worth of air to your warm tyre.
This is because if you add 1psi to you warm tyres this will reduce to 0.9589psi as the tyre cools (assuming that it cooled to ambient and that the ambient air temp was the same as before).
To your warm tyre you need to add 1.0429psi to the warm tyre to get your 1psi cold tyre equivalent (subject to the same ambient temp caveat as above).
[I am not a geek]
Old 29-10-04, 01:27 PM   #16
Warren
i got a footpump - but it only goes up to about 35 psi.
got a digital gauge - but my garage is a BP and has a new air thingy - you type in the psi you want and it does it all for you.
its accurate to my handheld (it reads at 36.02 kinda thing - so pretty accurate in my books )
Old 29-10-04, 01:52 PM   #17
Iansv
Warren, If your around tomorrow you can always pop round my way and use my footpump, goes upto 100psi..
I'll be doing some work on the bike and so will be around. I think you have my mobile number if not pm me
Old 29-10-04, 01:55 PM   #18
Jabba
Originally Posted by Iansv
"If toast always lands butter-side down, and cats always land on their feet, what happens if you strap toast on the back of a cat and drop it?"
Depends which way up you put the toast on the cat's back
Old 29-10-04, 02:47 PM   #19
jonboy
Then buy another one you tight git. Should be able to get something good enough for the job for a tenner.
Old 29-10-04, 03:05 PM   #20
Iansv
Yep Halfords they are £8.99 for the cheap and nasty one
Anybody got a HG Tricky jacket? jamesw1024 Riding Gear 12 20-04-08 09:37 PM
Tricky question.... Caddy2000 SV Talk, Tuning & Tweaking 11 27-09-07 06:35 PM
tricky stickers leon c Bikes - Talk & Issues 8 02-07-07 06:47 PM
Any swimmers on here ? A Tricky challenge tricky Idle Banter 23 19-04-07 02:57 PM
Hmmm....looks tricky TC3 Idle Banter 3 21-05-06 08:34 AM
