#11 | ||
#12 | |||
Please see my damaged fairing for sale in the for sale section ![]() ![]() |
#13 |
During my 15k service they changed the oil, coolant and brake fluid and bled the systems within an hour.
...but i had to pay them ![]() |
#14 | ||
#15 | |||
#16 |
I don't see the sense in risking swallowing brake fluid. Why not just get a good sized length of rope (preferable nylon), pump the lever till you get resistance, then use the rope to tie the lever in the squeeze position (a slip knot would work best) When you undo the bleed nipple, simply pull harder on the rope, and the lever should go all the way to the bar. Once it is there, close nipple and repeat. (dont foget to keep the rope tight till it is done) Just another approach.
( I must disclaim the above by saying that I haven't actually tried this. Just seems like it might work. ) |
#17 |
Done it!!!!!!!! took res cap off this morning watched bubbles rising for a few mins topped it up. pump three times fluid comes out of nipple. 10 mins late both sides done. thanks for all your help.
Helpful hints in sv manual suggests to leave over night if no feeling at lever after pumping to allow air to rise into res. it must have been doing it all night and i got to see the last few bubbles. Too slippery outside to test put note on handle bars to remind me when it comes out of hibernation. |
#18 |
So the top was off the reservoir all night? Isn't this a really bad idea with brake fluid?
#19 | |
However, it sounds like the cap wasn't left off over night. |
#20 | ||
braided brake hoses | Pam | SV Talk, Tuning & Tweaking | 17 | 15-10-08 03:11 PM |
Brake hoses. | Pam | SV Talk, Tuning & Tweaking | 13 | 09-09-08 02:55 PM |
Blimey! Brake hoses | chazzyb | SV Talk, Tuning & Tweaking | 7 | 05-05-07 07:48 AM |
goodridge brake hoses | kwak zzr | SV Talk, Tuning & Tweaking | 0 | 22-10-06 05:09 PM |
Rear brake hoses | kevbuck | SV Talk, Tuning & Tweaking | 26 | 26-11-04 04:11 PM |
