#11 |
![]() ![]() ![]() That'll be fun in the snow n ice ![]() I'd ride up, as there's no way I'd push the bike up that. |
#12 |
shouldn't be a problem riding up that..... except if icy.....
wouldn't dare push it up tho |
#13 |
I'd ride up that, my driveway is pretty steep, I can just about push my bike up it, but I'm knackered when I get to the top, I always forget and park to close to the garage door so I have to get through a tiny gap to get in the garage as well
Like the other said, just cover the back brake and take it steady, you'll be fine
#14 | |
http://www.bmwmotorcycles.com/k1200s...200s_specs.pdf When I noticed this section on weight :- DIN unladen weight ( lbs ) 545 lbs Dry weight ( lbs ) BMW Standard 499 lbs (with dry battery) Dry weight (lbs) Japan Standard 488 lbs (without battery) There's 57 lbs difference between DIN and Japan standard so an on the road SV will weigh quite a bit more than 162kg. Not sure about the DIN standard but I think it includes petrol. |
#15 |
I can't believe your trying to push the bike up that... the engine is there to do the pushing...
If you get up enough speed you won't even have to open the gate either ![]()
Innuendo - it's great when you get it. sv650s (gone) gsx-r600 (gone) Street R675 (now living in Inbhir Nis ) |
#16 |
Thanks for all the advice!
At the moment I have a Bandit 6 (faired) which weighs 210 kg dry, so about 230+ with petrol/oil, etc! - i have managed to get it up that drive and it was like hell. I currently park in my mate's garage ![]() I definitely agree with riding up,I think if I push it up and it falls away from me then that'll be my no-claims bonus going up in flames. One further question, do you think Is there enough width on that path to comfortably get up with both legs down with an SV? I thought about starting the run about 3/4 the width of the path across giving me some clearance from the wall!! I'm going to re-tarmac it as well with some of that nice anti-slip playground stuff which should help somewhat. Cheers Martin |
#17 |
I had my bike collected by the dealers for repairs after a minor off. They loaded it into a transit van - which involved riding up a metal gangplank into the van which was well under a foot wide and very steep - also nothing but thin air on either side should things go wrong, and very little braking distance - only the length of the van. The plank did have small lips on either side, but it was still very scary to watch. They went in fast, straight and braked very hard.
I think i agree with you in keeping away from the wall as much as possible, but also keeping your weight to the wall side so if you have to stop, you're not trying to put your foot on the steps. That would indicate going up on the left hand side if you want to cover your rear brake, although keeping two fingers over the front brake would probably do the job. If its icy, er... well... good luck :P ![]()
Silver SV650SK3, Fuel exhaust |
#18 | |
#19 |
Do you ride down "front first" Or roll it down backwards using the front brake and clutch (in gear)?
#20 |
I'd ride up it, I'd drop it or something if pushed. You apear to have a large area at the top to stop in so thats good.
Or you could move somewhere flatter... ![]() |
Your height/weight | Law | Idle Banter | 169 | 13-03-09 04:33 PM |
How much weight?? | dizzyblonde | Bikes - Talk & Issues | 8 | 18-02-08 12:06 AM |
Anyone else here trying to put on weight? | rubberduckofdeath | Idle Banter | 143 | 30-10-07 05:19 PM |
What weight oil do you use? | andyb | SV Talk, Tuning & Tweaking | 23 | 24-06-07 02:27 PM |
Bar end weight | Diveboy | Stuff Wanted | 4 | 07-02-06 02:48 PM |
