Old 16-01-05, 06:31 PM   #11
BURNER
Interesting about your tacho, going bonkers when you switch on. Does this mean you haven't got that functioning at all?
A clever mod, can't wait to see some detailed pics.
I watching a set of K3 clocks on ebay, went over my ceiling for them. Must have been you that bought them...
Old 16-01-05, 07:38 PM   #12
Stig
Originally Posted by Cloggsy
See... You're all coming around to the thinking that the K3+ is best
This is true in part. Come April I will have a K3 rear light fitted to the solo seat unit as well, albeit in an unconvential method. Not going as far as having a "pointy" frame though
Yes it does function. The needle rises when I open the throttle and falls when I ease off. It's just that it seems not to read the signals correctly and jumps all over the place.
Old 17-01-05, 08:19 AM   #13
The tacho and the temperature gauge were the only likely problem areas with doing this swap, the early bike has no temperature gauge as such, just the high temp led, therefore as the later bike does have a gauge we knew that was likely to be some circuitry missing from the electrcal system of the early bike, however as details of the internal circuitry are hard to come by, it wasn't possible to check this first. It's most likely that the early clocks have a simple circuit connected to the sensor on the 'stat housing, which is a variable resistor, the resistance of which is affected by temp, once the resistance changes to 'x' figure, then the temp led lights, all the relevant circuitry, (not much), is housed in the clocks. On the later bikes the wire that connects to the gauge comes from the ECM under the seat, so it's obvious that there is something in there which takes the temp sensor output and turns it into a guage reading, we don't have this so it's unlikely we can make that work without a better understandng of the internals of the ECM *.
On a more conventional system the tacho has a current supply and one connection to a convenient point on the low tension side of one coil, simply put the tacho counts the pulses, (1 per spark), and deduces from that the engine speed, no need for any other components necessary, all self contained, on the injected models however the tacho is also connected to the ECM, having had a look at the circuitry of the later tacho, there's nothing obviously unusual about it, but it doesn't work properly when dirctly connected to the earlier bike, as yet it isn't possible to know why, I suspect that simply the trigger output voltage from the ECM is at a different level, whether this is higher or lower, or for all we know yet instead of one pulse per spark it could be one for every 6 2/3rds sparks.
Anyway BillyC wants to bring his bike round for a small job to be done and he has very kindly offered to let me test his bike and find out what's happening with the electrical system of a late bike and what we might do about it.
So there might be more on this when we find out what happens in injected bikes 'leccy systems.
* Anybody got a K3/4 ECM they want to let me break? No...what a shame.
Old 17-01-05, 11:09 AM   #14
coombest
Errr...
Perhaps!
The on eon my nackered SV is still intact (I would imagine) and as you know, I will be breaking the bike... I'm sure some sort of arrangement could be made!
(Although, I'm not able to touch the bike yet as it may need to be re-assessed, it is now in my posession!!)
Old 17-01-05, 01:33 PM   #15
Originally Posted by coombest
Errr...
Perhaps!
Groovy baby
Tell me when.
Old 17-01-05, 05:31 PM   #16
Stig
Isn't that what I said
Old 17-01-05, 10:30 PM   #17
Errmmmm...probably, yes.
Old 09-02-05, 11:50 AM   #18
mick24
If you have'nt got a permanant feed to the K3 clocks or you disconnect the harness from the clocks for more than 40 seconds,the next time you switch the ignition on - the rev counter will go up to 7000 rpm to calibrate it's self - hope this explains it.
Old 09-02-05, 09:49 PM   #19
Brucey
If you are driving the Rev. counter off the LT side of the coil you will destroy the clocks as the signal is normally a nice low voltage square wave coming from the ECM not a horrid spikey high voltage that you are currently feeding it.
You will not be able to get the Temp. Gauge to work as this gets its information from the ECM and sends it in serial form to the clocks along with the fault codes hope this helps.
How Do I Change The Clock daz311066 Bikes - Talk & Issues 4 31-03-08 06:38 PM
pointy clock cover(thingy on the back of the clock)!!!! ben650 Stuff Wanted 0 09-04-06 12:47 PM
Clock on K3 lukemillar SV Talk, Tuning & Tweaking 3 08-02-06 08:06 PM
Can somebody set the clock timwilky Idle Banter 9 30-01-06 10:40 AM
Clock for K3 onwards PLAYAROUND Stuff Wanted 2 18-11-05 07:19 AM
