#11 |
Seeing as you had all that trouble getting the caliper apart just recently, I would think it likely that the pins on which the caliper slides side to side are stuck, the brake will pump up fine - you've got several hundred psi in the hydraulic system to do this - but it's not necessary to have much drag in the pins for it to be difficult for the brake to release itself.
I might be sticking around, so hello everybody | mark grinyer | Idle Banter | 18 | 29-09-08 04:05 PM |
Sticking, Jerky front brake. - FIX | Mark_h | SV Talk, Tuning & Tweaking | 5 | 13-12-06 01:36 PM |
damaged thread of brake calipar mounting bolt | Warren | SV Talk, Tuning & Tweaking | 8 | 19-05-06 02:27 PM |
Sticking reg/reg? | northwind | SV Talk, Tuning & Tweaking | 16 | 29-01-06 11:25 AM |
Sticking Choke? | aero99 | SV Talk, Tuning & Tweaking | 1 | 16-01-05 03:10 PM |
