#11 |
It's probably nothing more than adjustment as Dan has said, which is unlikely to be fixed from just the thumbwheel at the lever. It'll need the front sprocket cover removing and then resetting from there. As the SV's clutch is pretty strong it's unlikely to be shagged. Replacing the clutch plates is about £40 in parts and not a big job to do (apparently).
As for the front brake that's a mystery, seems as though you've not got hydraulic pressure, so maybe you've sprung a small leak and air has got in to the system, or the temperature of the fluid from constant work has gone past it's normal operating level and is now shagged. Doubtless the wisdom of Sid Squid, Rictus, Embee etc will offer a more accurate appraisal. . |
#12 |
arghhhhhh i cant f$%^ing do it it does not seem to be making any difference
#13 |
hey thanks to everone dont stop with the advice it's a great help. by the way the front brake works ok in normal use just wont hold the bike whilst doing the burn out at revs above about 3.5/4
#14 |
Sorry...
![]() ![]() We did warn you! Are you sure that you're turning the adjustment the right way? You should be screwing it in to the lever to bring the biting point closer to the bar. However, nearly fully let out is about where it should be before things bite - makes for neat gear changes see!
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
#15 | |
Where the hell am I?
I got an interview in the morning so i really dont wanna mess with the bike and be late for that.
. "Computers are great! Not for communicating tho. They have one fundamental flaw ... they don't have eyebrows." AlpineCarStereo: you win ....... eeerrr ..... ummm ..... my undying support of you, the greatest Mod this forum has ever known. My Leige. davepreston: ![]() |
#16 |
bloody hell still can't do it i am just poking around aimlessly don't know what i am doing. clueless i am seen women with better knowledge of bike
#17 |
Someone else that lives in Eltham
![]() This reply hasn't been much help. ![]() |
#18 |
Hi hall 13uk
You've just reminded me why I always buy new!!! |
#19 | |
#20 | ||
