Old 15-05-05, 02:56 PM   #11
Jezza
Thanks for the replies. Was just something that went through my head. Not many things do so i thought i better write it down.
I will get a Staintune can, just for the sound really, and i've already stuck a BMC airfilter in it. 18'000k service and will be cheaper in the long run. So i might as well have someone who knows how to fiddle with the carbs eventually. If that gives it extra ponies that's nice, i probably won't notice it with how i ride though.
A huge improvement has come from the Metzeler Sportecs i now have on it. Bumpy, slow corners that used to cause much sphincter puckering i can now go through faster and without any dramas at all. They stick SO much better and they actually give me a bit of feel. The increased bump absorbtion by the tyres is actually that good that i'll be adding a bit more preload front and rear. Amazing. I'm riding a little bit quicker with a lot less effort now.
Old 15-05-05, 06:04 PM   #12
how much were the sportecs??
I have metzler ones on as standard z4 or wotever they are- and I feel like I am on ice.!!
if ihad em took off i cud prob sell em on cos they as new !! but i dont gel with them!!..
Old 15-05-05, 06:42 PM   #13
Roadtec's a much better choice unless you're going to do a lot of trackdays... Sportec takes longer to heat up, and doesn't really offer much more in the real world, not to mention being less good in the rain or winter and about a third as durable... IMO!
Old 16-05-05, 12:38 AM   #14
Jezza
I paid 450.-AUSD for the set (however many squids that is), no charge for fitting them.
I had Sportecs on the CBR when i still lived in Switzerland. Never had any problems with them heating up. They gripped very well even on cold, damp roads.
Not an issue here in Oz. I take it easy through the first few corners, then go for it.
As i wrote already i have found that there's a lot more to tyres than grip. Maybe the Roadtecs will improve feel and absorb bumps as well as the Sportecs? Even if it weren't for the much higher amount of grip the Sportecs offer they'd **** all over the BT020s... IMO.
It's hard for me to see how you could do track days with tyres like Z6s or BT020s. After a few laps tyres like BT010s (in 2001) and Sportecs start to get (too) hot, and they're sposed to run at higher temps...
Old 16-05-05, 01:00 AM   #15
irl_dar
just go buy a tlr...
*runs* :P
thats what i did!
Old 16-05-05, 12:47 PM   #16
chewy22
Originally Posted by Carsick
because when you buy a bike it's not just about the power figure.
oh, and plus, it's fun to mod.
I started just with removing the ugly rear end now I just can't stop. And I have loads more to do. Like GSXR rearsets build (finish) the new swing arm powdercoat the swing arm and frame black GSXR USD forks. Fit a RI year 02 rear end and seat.
MOD LIST TO DATE
CLEAR Tail Light with Turn Signal Integration http://www.highgearhobbies.com/esto...es/CTL-0075.gif
Custom fit grommet kit in hangers and swingarm pivot points
Shorter gear shift arm from a TLR part No 25520-19co2
MIRROR SPACERS www.chewys-stuff.co.uk
Blue gauges conversion www.chewys-stuff.co.uk
Grommet kit www.chewys-stuff.co.uk
Suzuki seat hump
Scott oilier www.scottoiler.com
Crash bobbins JHSRacing www.jhsracing.co.uk
Hugger Ermax Under tray Ermax
Double bubble tinted screen BUSTERS
Wavy disc rear plus Goodridge S/S BREAK 3 LINE KIT
SV996R STICKERS www.chewys-stuff.co.uk
Oval double outlet cans ART S/S LOUD (not for road use)
BREAK AND CLUTCH res caps silver OBERON www.oem-uk.com
Foot rests OBERON + www.oem-uk.com
Drilled & polished HEEL GUARDS
Bar ends stainless steel OBERON
Oil filler cap silver OBERON
GOLD sprocket nuts
Fender extender PYRAMID
GPS Gear position indicator with a TRE cleverly fitted into the circuit modified from a TLR kit
Snorkel removal
Raised front of petrol tank by 16mm www.chewys-stuff.co.uk
Tank fillet carbon look
Clear indicator lenses front CLEAR ALTERNATIVES http://www.cruisercustomizing.com/l...=308&model_ID=0
Clear indicators rear from a FORD car RS model
Tax disk holder www.chewys-stuff.co.uk
RAD grills HAMICAD www.hamicad.co.uk
Rear footrest eliminators http://cgi.ebay.co.uk/ws/eBayISAPI....7929375982&rd=1
Number plate bracket home made with Lites in bolt`z kit added
Removed the steel right hand bracket on right footrest
Alloy cotton reels
MY ANGLE CAN MOD www.chewys-stuff.co.uk
Dropped front forks through clamps by 5mm
Replace about 110+ bolts with stainless steel (CRAP FINISH)
Delrin MIRROR SPACERS my product www.chewys-stuff.co.uk
Suzuki top yoke cover and tank filler cover
Modified side stand to stop it falling over
Replaced all engine bolts with stainless steel My product www.chewys-stuff.co.uk
PAIR block of kit and TOTAL removal of system. My product www.chewys-stuffco.uk
The GAP modification. Removed rear brake res fitted custom made one under rear seat. Cut off excess plastics and steel bar between sub frame hidden tip over switch under tank with custom fitting.
Mirror polish swing arm.
Modify steering damper.
Hidden horn under the tank
Spray paint silver the large bracket behind the oil cooler
Black wheels powder coated, Gold callipers powder coated, sub frame powder coated black www.triple-s.co.uk
Gold DID X ring chain fitted to black anodised sprockets. From Renthol
Rear sprocket carrier powder coated gold
Old 16-05-05, 04:54 PM   #17
As i wrote already i have found that there's a lot more to tyres than grip. Maybe the Roadtecs will improve feel and absorb bumps as well as the Sportecs? Even if it weren't for the much higher amount of grip the Sportecs offer they'd sh*t all over the BT020s... IMO.
The Sportevcs certainly aren't bad in the wet, they're just not quite as good as the Roadtecs... In my experience the Roadtecs grip as well in near freezing wet conditions as the Sportecs did in warm wet conditions, and are better in the warm and wet, especially when leaned over. I never got to run the Sportecs in winter though, just late spring.
IMO the big drawback of the Roadtec is feedback, I get far less than I did with the Sportec- but then, I often found the sportec overwhelmed me with irrelevant feedback when pushed, as it went over tiny bumps or stones etc... It's obviously esigned that way but for me that's not what I need when I'm pushing. While the Roadtec takes that sort of thing in its stride, it's just a little lacking in straight-line feedback and warning (that's why I'd say keep it off the track if you plan to really push). I prefer the balance that the roadtec strikes.
And of course, there's the 3:1 rear wear ratio To be honest, the Roadtec will keep even a fast road rider the right way up unless they're doing something inherently stupid, and without scaring them to death, so sacrificing lifespan for further grip that I won't use just doesn't seem like a good idea.
Old 17-05-05, 03:47 AM   #18
Jezza
To each their own i guess. Even with the Sportecs i'd like much more feedback, can't have enough. I know that other people can get a bit unnerved with too much of it.
I seem to do stupid things every now and then, so needing new tyres more often will still be cheaper than having to repair the bike. And i'm more comfortable with the extra grip that's in reserve.
Mr Chewie, you went nuts on your SV there! I quite like it , i'm just not into all the 'personalising' like most people are
Old 17-05-05, 01:02 PM   #19
Couerdelion
I think you would be surprised by the number of peopl ewho keep their bikes standard. I can't understand it as the first thing I wanted to do was remove the Snow plough off the back and get a different exhaust. But as you say horses for courses.
Old 17-05-05, 08:39 PM   #20
It's not so much too much feedback, just things that you have no use for at all, like "just went over a tiny crack in the road." The only time I did ever manage to completely overwhelm the Roadtecs on the street, they let me know all about it
I don't want a tyre with less feedback than the Sportec; I want a tyre that's more selective, if that makes any sense. There's a level of events which are just IMO of no relevance whatsoever to the rider, small stones, micro-slides in corners, that I'm glad to be without so that the important information's not swamped. Think of it as signal/noise ratios...
