#11 | ||
![]() Seriously though, is it just down to that? I'm sure I do need some alignment done on my SV.
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
#12 |
since i had new tyres fitted mine drifts to the right...
#13 |
hello boys!
the bike is not going to the right so badly...i know only , that i set the rear wheel correct with the marks on the swingram...so, as most of you say, probably wouldnt worry about it... will drive in the middle of the road ![]() |
#14 |
Why would you WANT to take your hands off the bars ??
#15 |
i just want to make me bike perfect...i adjusted the chain another day, so i thought maybe i did something wrong...but did everything by the manual...the marks on the swingram for the rear wheel to set are the same on the both sides...
am a bit confused.. ![]() |
#16 |
don't use the marks to align the front wheel. I'm sure someone will be along to explain the process of doing it without - bits of string involved i think.
Silver SV650SK3, Fuel exhaust |
#17 |
did some aligning with the rear wheel...could do the test ride, cos its was badly raining over here. will do it tomorrow, staright after work
#18 |
thank goodness I don't go to Lithuania
![]() ![]() stop taking your hands off the bars...........no problem ![]() ![]() |
#19 |
In my experience if the bike pulls to the right with your hands off the bars (consistently) then the back wheel is pointing to the right, i.e. the right-hand chain adjuster is oulled further back than the left one. The swingarm marks aren't very clear or accurate - use them as a guide only. Try adjusting the left-hand chain adjuster half a turn more (pulling the wheel back on that side) than the right, ride it again and try it. Another symptom of when it's wrong is that you might feel it go into right-handers more easily than left-handers. Give it a go. Never tried the bits of wood-string thing, but this has always worked for me.
#20 | |
Handlebars | suilven | SV Talk, Tuning & Tweaking | 3 | 31-12-07 11:53 AM |
Handlebars | tomjones2 | Bikes - Talk & Issues | 4 | 15-10-07 10:45 PM |
Handlebars | Fraser24 | Stuff Wanted | 0 | 17-07-07 05:10 PM |
Things To Do In A Lift | Samnooshka | Idle Banter | 13 | 13-07-06 09:58 PM |
Bike Lift | minky | SV Talk, Tuning & Tweaking | 5 | 12-12-05 04:32 PM |
