Old 24-08-05, 06:49 PM   #11
SPeeeeDY
I had my tyres at normal road pressures on my recent trackday. After 2 sessions i was virtually given a tellingoff by one of the racers there. He put my tyres (pilotpowers) to 29psi front and rear.
The grip levels were unreal after that!!!!
It was a mad hot dry track though
SPeeeeDY
Old 03-02-06, 09:38 AM   #12
xj/frosty
Im running a racetec /rennsport combo on my race SV
When the tyres are new I'll run em at 29 rear and 27 front.
I try to get 3 meetings out of a set of tyres so I drop the pressures a tadd to compensate for the heat cycles.
If you want an UNREAL riding experience in the rain--try a set of full on wet race tyres.On a recent practice day it bucketted down at lunchtime--I did one session on the metzlers then put on the wets-You just will not believe the grip you have in the wet
Old 03-02-06, 04:18 PM   #13
Balky001
Balky001's Avatar
As many have already said, the pattern of road tyre has been designed to be at its most effecient at the standard pressure settings.
I reduced my tyre pressures from a normal 36/36 (GSXR600) to 31/30. When I was lucky enought to have a Niall MacKenzie as my track day tutor (between 3 of us!) at Donington, he said we shouldn't worry about tyre pressures at all at the speed we were going. Considering we were mid runners in the advanced group and it was a very hot day, I'm guessing you'd need to be running at a pretty fast rate for the pressures to make any difference. That said, if it improves your confidence then you'll be faster.
I mate had his tyres filled with nitrogen - as it is water vapour free apparently you don't need to drop your pressures anyway, as the gas does not expand like air
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Tyre pressures Matthie Bikes - Talk & Issues 9 22-03-09 08:41 PM
Road Tyre Pressures and tyre problems G Bikes - Talk & Issues 14 05-06-08 03:29 PM
Tyre Pressures 14990 Bikes - Talk & Issues 1 22-09-07 05:54 PM
tyre pressures ? DAX SV Talk, Tuning & Tweaking 20 12-12-06 09:28 PM
Tyre Pressures fizzwheel Tyres 21 26-03-05 09:04 PM
