Old 16-08-05, 10:15 PM   #11
The valves rarely go out of adjustment it's true, but I'd consider it most unwise not to check them.
Checking is easy, adjustment isn't so easy, repairing a broken one is harder still, not to mention dear. It may not be likely that they'll be out, but is possible, I'd rather know.
Old 16-08-05, 10:56 PM   #12
TSM
The Sick Man
TSM's Avatar
I was thinking of having a look at them as my bike is now nearing about 19-20k. But when, i dont know.
I think the noises coming from my bike is the cam chain tens, so probably i will do it all at the same time.
Old 17-08-05, 06:36 AM   #13
SteveR
If you're bothering going to a suzuki dealer 'to keep up with the warranty', then you should also make sure that the service is carried out in accordance with their plan. (I'm not convinced that you lose the warranty by going elsewhere tho).
The valve clearances are easy and quick to do if combined with other jobs.
I've done mine when changing coolant - once the radiator's off then the front clerances can easily be checked (and the front plug's a doddle). It also gives a chance to clean the cam covers. The rear cylinder isn't too much trouble anyway.
The engine does have to be *stone cold*
Brakes and sprockets could be done by onyone to save money.
Old 17-08-05, 07:30 AM   #14
Viney
£350 sounds a tad extortionate tbh. The most expensive service i have ever had was £249!! As for the vavles. My bikes at 41000 and to date has never needed to have its valves adjusted. They are checked every 16-20k.
Old 17-08-05, 06:14 PM   #15
Bonart
Had mine checked at the 15k service with new rear brake pad & new choke cable fitted and the bill came to around £280 ish. £353 to start with sounds expensive.
Old 17-08-05, 06:28 PM   #16
Red ones
Red ones's Avatar
Warranty sticks if the schedule is adhered to - proving it is the difficult bit tho. Europe did get something right for once!
Old 18-08-05, 08:56 AM   #17
The Mass
Just dropped her of this morning.
The actual price is £299 inc vat and bits and labour etc..
I think the £335 (Sorry got353 from somewhere) includes a new front tyre which I had to pre-order.
BTW: I've just had 16.5k out of the front tyre verified by 2 independant bikers in work, that it still had life in it this morning as well.. and NO I don't wheelie all the way to work
Shocked myself even
Mass
Old 18-08-05, 09:00 AM   #18
Nagai
And what lovely courtesy bike did you get from them?
I remembr getting a ZX6R when my sv had it's first service! Mentalo bike, scared myself senseless on it on the M57 on the way home from the dealer! Fantastic! Still want a little 600cc four cylinder bike!
Old 18-08-05, 09:04 AM   #19
The Mass
I knew you'd ask...
GS500...I've done nothing but Pi$$ myself laughing all teh way back to work. the flow of air on a naked is wonderful. Tried taking her over 75mph to overtake a van, and my hands went numb from the vibes in the handle bars lots of fun!!!
I'm Still laughin now and that was about an hour ago..
Old 18-08-05, 09:07 AM   #20
Nagai
GS500? Tarts bike! lol
You would have loved my H100S on the 7 1/2 hour trip to Norwich that December! Or the 4 hour trips to Taff land! (Same time as in the car, incidentally! unless you are Mr."Ayrton"Mass Sr!).
Valve Clearance Readings Mr_Chin SV Talk, Tuning & Tweaking 2 22-12-08 08:54 AM
Valve clearance checking. Mark_h SV Talk, Tuning & Tweaking 6 22-12-08 08:31 AM
Valve Clearance Tight stnd SV Talk, Tuning & Tweaking 2 02-09-08 10:52 PM
A question of valve clearance... BillyC SV Talk, Tuning & Tweaking 11 23-11-05 12:36 AM
Valve Clearance Craig SV Talk, Tuning & Tweaking 3 14-02-05 07:34 PM
