Old 30-01-06, 01:47 PM   #11
Oh aye... It's entirely possible the lifter mechanism at the end of the cable has chewed itself up- mine spat out all its bearings so it was metal-on-metal every time i used the clutch. Improved my grip strength no end
Old 30-01-06, 01:58 PM   #12
gc350
Any advise on what bit are needed for the conversion?
Old 30-01-06, 02:02 PM   #13
TSM
The Sick Man
TSM's Avatar
A complete hydro clutch kit from a TL. Best place to get them is on TLP as many people have converted their TLR hydro clutch to a cable one.
Contact RizlaSV, her partner had a TLR and i was going to get the kit from him.
If there are any other mods needed i am not sure. But the kit is from a TLR.
Old 30-01-06, 02:02 PM   #14
dieter
I bought the complete set on Ebay from a crashed DL1000 for 35€ then i bought a new grip?? (10€) Thats it...
Greetings
Dieter
Old 30-01-06, 02:04 PM   #15
gc350
What work does the swap involve?
Old 30-01-06, 02:06 PM   #16
TSM
The Sick Man
TSM's Avatar
Greetings
Dieter
I am guessing the DL1000 is the same engine as a TLR more or less?
Did you have to modify the front sprocket cover, what about the push rod, original one or the one from the DL?
Old 30-01-06, 02:40 PM   #17
Cloggsy
Greetings
Dieter
The DL1000 is the VStrom (is it not ) If so, the DL has the SV1000 lump in it
Old 30-01-06, 02:41 PM   #18
TSM
The Sick Man
TSM's Avatar
Is it possable to have a close shot of the hydro assembly?
Old 30-01-06, 08:20 PM   #19
tj2
tj2's Avatar
Hello,
I have the hydraulic Cluch from the TL/DL/SV 1000 on my 650.
here in my album
Greetings from Germany,
Dieter
Nice belt drive conversion too.....
tj2 is offline   Reply With Quote
Old 01-02-06, 10:41 AM   #20
triumph5ta
New cable = £11
Also check the clutch lever hole where it pivots around the bolt on the handlebar fitting. If this hole is oval ie it is no longer round then that will make the action heavy and awkward.
Buy a genuine Suzuki lever if you need to replace it. About £17.
Hydraulic clutch - advantages? Ed Bikes - Talk & Issues 46 01-09-08 01:02 PM
Any Hydraulic/Mechanical Engineers in here? Cam_73 Idle Banter 5 30-01-08 07:55 PM
Hydraulic clutch mod Damoulianos Marios SV Talk, Tuning & Tweaking 22 21-06-07 12:49 PM
Rear Shock Hydraulic Pre-load Adjusters Luckypants SV Talk, Tuning & Tweaking 5 31-01-07 05:02 PM
hydraulic clutch SV-Sexy-virgin? SV Talk, Tuning & Tweaking 7 21-02-05 11:45 AM
