Old 11-09-05, 08:33 PM   #11
BillyC
BillyC's Avatar
VTEC.... Honda's brand of Variable Valve Timing and Lift.
The Honda VTEC engines rev high (not exactly motorbike revs) because that's how they're made - light and revvy, but their talk and power delivery is also like an I4 bike engine - nothing low down, but all the power kicking in high up.
For the first few thousand RPM, an S2000 has little more power than a Ford Fiesta No really!
In fact, the 2 litre Honda lumps power claim is a bit dodgy... the 200bhp or whatever it's supposed to make doesn't come until 8000 rpm, and the red-line is somewhere just the other side of 9000 rpm.
There are many engines that benefit from VVT&L... and it's simply a way of delivering power, when it's really required. It might work well on the 650 Vee... and help remove some of the snatchy power delivery that is associated so much to the SV.
Old 11-09-05, 08:36 PM   #12
All IC engines benefit from appropriate valving, the timing, lift and duration off the cam's lobes are always set as a compromise between the optimum settings for differing engine speeds, some systems actually change those settings, that's variable valve timing. There are several cars with this sort of system, I think that Suzuki made a few small fours like this too.
Honda do things slightly differently with their VTEC system, the VFR has four valves per cylinder and at low engine speed only one inlet and one exhaust open, this means that the gas flow passes through a smaller area and thus travels faster, (for any given volume), going faster means that the gas has greater momentum, and this improves the volumetric efficiency and cylinder scavenging.
There's no engineering reason why you couldn't do it to any four-stroke engine, but of course you'd need to examine the economics, I doubt it would make much sense, (as the technology stands now, won't be long I'm sure), for smaller simpler motors.
Old 11-09-05, 08:56 PM   #13
Peter Henry
VTEC------SPEETEC! Pah! Where would I be without the hammering and banging from my desmodronics??
Old 11-09-05, 10:56 PM   #14
The Basket
I read about it in a magazine...the fact I've heard nothing else seems as though it has been dropped.
The idea of V-TEC is to give optimum performance at low revs, then changing to optimum performance at high revs. This could work on a bus like the CB1300 but it would be banging on and off on a SV.
A Hayabusa is designed to go 180mph+ and so would be ineffecient at 30mph...cut the number of valves and power and Hey Presto...more effecient at 30mph...better fuel economy.
Why you would buy a big bike and ride at 30mph is another matter.
I can't imagine riding a bike on Spanish roads...it makes our roads look sane.
Old 11-09-05, 11:12 PM   #15
Warren
the VTEC doenst go down very well with many honda owners, its a common mod to disable it.
Old 11-09-05, 11:27 PM   #16
The Basket
I'm sure the V-Tec will join the linked brakes and automatic gearbox in the Honda museum of 'answers to questions no-one asked'.
Old 12-09-05, 08:47 AM   #17
Ivar
Default Re: VTEC
Originally Posted by The Basket
Why have VTEC? No purpose I can think of. An answer to a question no-one asked. And on a small engine? Especially a revvy one? Adds complexity, increases service costs,
I agree , according to the VFR owners i know, it don't seem to help the low end that much , and the transition in the 7000rpm range can be disturbing, especially mid-corner.
Old 12-09-05, 02:22 PM   #18
I think judging VTEC on how well it works in the VFR would be a bit unfair... it seems to be a pretty common concensus that it's just done badly on that particular bikes. VVT of some sort is finding its way into quite a few different applications, after all.
Old 12-09-05, 05:35 PM   #19
The VTEC system fitted to the Honda VFR is not a VVT system.
Old 12-09-05, 05:47 PM   #20
That would be a question of definitions, I think? After all, VTEC stands for "Variable Valve Timing and Lift Electronic Control"
Honda VFR Vtec joelowden For Sale - Other Bikes and General biking items 6 14-05-09 04:16 AM
