#11 |
Hi All, Just can.t understand why this mod works , is it tricking the ecu in to thinking you are opening the right hand quicker than the standard tube.
and will it work on my K3 andy |
#12 | |
#13 |
Am slightly confused is it 5SL-26240-01 or is it 5SL-26240-00 and whats the difference????
#14 |
About £7
![]() ![]() AFAIK they are basically the same but Yamaha charges more for one part number .Can't remember which one. Cheers Ben |
#15 | ||
I only have one cable. Makes the throttle much more snappier! |
#16 | |||
#17 |
I had a lot to do with efi on cars some years ago and the aftermarket system I fitted used the throttle pot as we have on the SV's not only for position but for rate of change of the pot, this gave an extra wide timing for the injectors as it new that the engine was accselerating. and dependent on how short or long the slam from closed was this gave larger or smaller opening times. a bit like a accel pump on the old carbs.
Using a larger grip will give shorter open acc time to the ecu. |
#18 |
#19 |
#20 |
I had a lot to do with efi on cars some years ago and the aftermarket system I fitted used the throttle pot as we have on the SV's not only for position but for rate of change of the pot, this gave an extra wide timing for the injectors as it new that the engine was accelerating. and dependent on how short or long the slam from closed was this gave larger or smaller opening times. a bit like a accel pump on the old carbs.
Need a new throttle tube | TightRS | SV Talk, Tuning & Tweaking | 2 | 23-12-08 10:13 AM |
R6 Throttle Tube | etuna | SV Talk, Tuning & Tweaking | 17 | 22-11-08 09:42 AM |
R6 Throttle Tube | plowsie | SV Talk, Tuning & Tweaking | 0 | 19-06-07 10:21 AM |
throttle tube | 01 sv650s | SV Talk, Tuning & Tweaking | 1 | 21-11-06 02:25 PM |
