Old 06-02-06, 12:58 PM   #11
Viney
Originally Posted by Sudoxe
The idle should be slighyl higher 12-1500 i seem to remeber?
Glad i helped someone not destory there bike though!
Dan
Yes Dan. You almost sounded like Squidward!!
Old 06-02-06, 01:58 PM   #12
Sponge
I swapped the plugs round, but its still the back cylinder which is having 'issues'.
Seems the idle could be alittle low then... but doesn't explain its temperamental issues on 'starting'.
Why Sudoxe, have you helped someone in the past in the premature demise of their machine??
Old 06-02-06, 03:03 PM   #13
Viney
His self!! I hope im not speaking out of turn, but Dan really had a steep learning curve when his own SV went pop.
If you know someone who has a compression tester, then do one on the rear cylinder. This will tell you if its anything serious with the piston/oil seals. If this shows normal, then i would look at the ignition lead, then the ECU. You could have bent a valve
Old 06-02-06, 03:11 PM   #14
Sponge
its all getting a bit complicated for me now...
Old 06-02-06, 03:15 PM   #15
Viney
Sorry, but you did ask
A comprssion tester is a thing that you screw into the spark plug hole that has a dial on the top. This will see if the cylinder is compressing to the proper ammount, something that it wouldnt do if you had a hole in your piston, or a blown pison seal.
The plag leads are the things that connect the coil to the plug (Could be breaking down when it gets hot)
The ECU controls all the fuel and sparking arangements. Located under the pillion seat.
Old 06-02-06, 03:22 PM   #16
BillyC
BillyC's Avatar
Might be a faulty injector, or injector connection.
Old 06-02-06, 04:02 PM   #17
Sponge
.... hhmmm so much to check ....
Think i'll have to take it to a dealer, as when it starts getting to ECU probs and Cylinder pressures I don't have the tools or expertise.
I'll check the injectors again, and all the connections... and hope its somethign simple.
Otherwise...
Another way round the problem ...
If there is anybody out there who really loves to 'ticker/mend' bikes...
If the answer is YES then read on...
The golden opportunity has arisen for you too take control of a bike which needs your TLC.
So you can get rid of your 'working' bike and swap it for one which has a problem or two for you to fix.
While your fixing my bike, I promise to do my best to add some new problems to your own bike, so you can again receive back another 'project' machine!!!
Old 07-02-06, 07:25 AM   #18
Sudoxe
It's true! I knew fa about fiddling with bikes when I bought the sv, and now I know slightly less.. Which is why I don’t usually give advise unless I’ve done that thing before, and not too many people on here have had the throttle bodies off pointy a sv. But, i wouldn't know where to start diagnosing this other than giving pointers on how to shoe-horn it all back together or rip it apart.
But it's all good fun, many an hour spent with both sid_squid and rictus and many others have helped me improve my spannering and tinkering, and the magic of the machine has demystified a little. My engine has pistons, cams, oil feeds etc now and not smoke and mirrors
Cheers guys
chitty chitty fecking bang bang hovis Idle Banter 35 03-01-09 12:33 PM
Big Bang R1 Ceri JC Bikes - Talk & Issues 2 24-10-08 01:37 PM
Bang! kwak zzr Idle Banter 9 05-11-07 11:03 PM
bang!!!! sv650nutter149 SV Talk, Tuning & Tweaking 18 15-08-07 07:14 PM
kill bill soundtrack bang bang hovis Idle Banter 8 22-05-07 03:53 PM
