Old 24-02-06, 10:45 AM   #11
Jelster
Carb icing ?? Just a thought.... Never suffered it with my curvey but I know it can be a problem. I always run my 'Blade on Optimax whenever I can, the tank range tends to be better...
Old 24-02-06, 10:45 AM   #12
Kate
Originally Posted by Saracen
I think it's probably not the fuel per se, but rather the higher octane stuff doesn't respond well to running lean maybe?
I actually changed to the higher octane stuff after the engine started cutting out on me and it seemed to reduce the frequency of the cutting out. Its just what I observed, and since I got better fuel consumption from the higher octane stuff, I kept with it.
Old 24-02-06, 10:49 AM   #13
Saracen
Has your bike been adjusted for the exhaust?
Old 24-02-06, 11:04 AM   #14
chazzyb
I believe the Tesco 99 RON juice is actually a 5% Ethanol/petrol mix. But I wouldn't have thought it would upset anything, unless it is icing with a change in fuel volatility. Unless an engine management system can advance the ignition timing to take advantage of the higher octane rating, it's debatable that you'll get any tangible benefit from spending more money over the cooking fuel.
Old 24-02-06, 11:17 AM   #15
Jelster
I think any noticeable change in performance is probably psychological, however, I do get better tank range on the good stuff, and many people say they get easier cold starts.
Whether the increased tank range is actually worth the difference in true cash terms, I always run my bikes from full to the light coming on, then look for a garage. If this means that I get an extra 10 miles or so from a tank then that's fine by me....
Old 24-02-06, 11:18 AM   #16
Kate
I believe it had, its not a problem now though as the SV is well and truely dead
Old 24-02-06, 11:32 AM   #17
jambo
jambo's Avatar
I only tend to see carb icing when I've been unning for a bit as it's to do with moisture in the air coming over the jets yada yada yada...
Check the battry's fully charged and the connections are good, but I'd think the cold's just causing it some greif.
I'm always happy with standard 95RON stuff from where ever, but it's doubtful anything higher would hurt.
Old 24-02-06, 01:15 PM   #18
BillyC
BillyC's Avatar
The fuel is fine, your bike has the compression to handle such fuels.
However, you have drastically affected the fueling of the bike, and the back pressure from the exhaust. It's no surprise that performance has been affected, and the tuning will be all off.
Get it checked.
Old 24-02-06, 01:16 PM   #19
Toypop
I'd stake a years wages that the fuel has absolutely nothing to do with it (unless it was a dodgy batch which is unlikely) so the answer to the original question is no.
Old 24-02-06, 02:06 PM   #20
Wootan
Afternoon all
I'm not sure how relevant this is but... I run a classic Lotus that is designed to run on 98 ron fuel, a few of the guys from my local club have tried Tesco fuel and nearly all have suffered from poor running. I'm not suggesting that this is the only problem in this case, but I certainly won't be putting it i my bike.
Paul
My Mate got killed on his bike on Friday caz650s South & West Surfers 38 05-10-08 08:03 PM
Tesco - How stupid can they get? wyrdness Idle Banter 16 11-06-08 12:12 PM
I killed my bike on death hill (WITH PICS) redeye321 SV Talk, Tuning & Tweaking 79 09-08-07 10:40 AM
Now I've killed it....my bike won't start! Kinvig SV Talk, Tuning & Tweaking 61 16-10-06 09:53 AM
Tesco Caddy2000 Bikes - Talk & Issues 62 27-08-06 03:33 PM
