Old 20-03-06, 08:16 PM   #11
TSM
The Sick Man
TSM's Avatar
Originally Posted by 21QUEST
Piece Ally.
Drill a hole in it and attach using a longer bolt (Front subframe).
Ben
My damage is on the frame headstock, dont understand what you are saying.
Old 20-03-06, 08:28 PM   #12
21QUEST
21QUEST's Avatar
Piece Ally.
Ben
Right , taking the dog out now. When I get back I'll post up a pic.
Ben
Nemo me impune lacessit.
Old 20-03-06, 09:37 PM   #13
21QUEST
21QUEST's Avatar
Pic on the left is a piece of Aluminium with holes drilled in them. I use that to make the lockstops operational with a GSXR K series bottom yoke. They were bolted at the headstock using the bolts for the headlight/clock subframe. Thinking about it it won't work 'as is' since it would probably be too thick.
The piece on the right is a strip of Aluminium which would have been another option as could be shaped to fit. Again probably won't work as very possible reduce the amount of steering on the left as well.
Now saying all that I think we are probably making thinks more complicated than it needs to be. IMHO your original suggestion of using chemical metal would work fine. Others may disagree :P
Ben
Old 20-03-06, 09:41 PM   #14
TSM
The Sick Man
TSM's Avatar
I only need it to pass an MOT in the short term, longer term i will want it fixed properly.
Old 20-03-06, 09:50 PM   #15
File the lug on the frame nice and flat, weld a blob onto the lockstop lug on the yoke, much easier than ally welding, then file it down when fitted so that the stop is where you need it to be.
It doesn't matter where the extra material goes - on the frame or the yoke - as long as the steering stops where it needs to.
Damaged lockstop, will it pass an MOT? SVmonkey Bikes - Talk & Issues 12 21-03-07 01:16 PM
Cat D damage ??? Stormspiel Bikes - Talk & Issues 10 25-02-06 07:35 PM
Damage Inc Ransom Bikes - Talk & Issues 18 09-06-05 12:34 AM
Need to fix my damage TSM Bikes - Talk & Issues 6 30-01-05 12:06 PM
No Damage? Really? Mike1234 SV Talk, Tuning & Tweaking 5 25-01-05 02:03 PM
