Old 22-03-06, 03:05 PM   #11
Grinch
Originally Posted by Scoobs
Good work Grinchy.
Cheers Scooby.
Old 22-03-06, 03:30 PM   #12
Viney
Originally Posted by 454697819
i forget which colour the wire is but i scotch locked sum unto the switched live under the fues box.... as far as i know it still holds up!
Alex
ohdearohdearohdearohdearohdear
Old 22-03-06, 03:53 PM   #13
rwoodcock01
Well done mate,
must do my grips as well, although gone through most of winter now, I have to admit, I am a little edgey about doing anything like that to the bike.
Rich
Old 22-03-06, 04:14 PM   #14
454697819
Alex
whats wrong with it.. i taped it up so it wont get water in it, its rated to 5 amps the same as the fuse in the heated grips IIRC, and solves the switching issue?
was it the spelling or do you have any words of wisdom? I was planning to hard wire it but it got dark and i havnt seen the person since who's bike i did it to.
Alex
Old 22-03-06, 04:16 PM   #15
Viney
Scotch locks are just a disaster to happen. Soooooo many times have i rectified these god damn things with proper crip teminals at the least. Soldering is better.
Just being picky
Old 22-03-06, 04:52 PM   #16
454697819
Just being picky
I will agree with you they are not the best sollution,, however i was trying a coupla wires as tbh the electrical diagram is a bit.. er... well you know..
Sadly i shant see this person again to rectify it, but as long as it works, then i was happy!
Alex
Old 22-03-06, 06:00 PM   #17
rob13
need to set up my scotty like that - much more effective by the looks of things
Old 23-03-06, 11:21 AM   #18
Grinch
Not really sure... seems to be working just fine. Though as the end of the oiler tube is cable tied and on a metal mount it is easier to adjust. Just got to get the flow rate right now.
Old 23-03-06, 11:46 AM   #19
andyaikido
How is yours set up? I've got a pointy too and have glued it to the bottom of the swingarm, out of sight. The only trouble i'm having is getting the oiler within a couple of mm of the chain. Can only get it to about 5mm away, maybe need to warm it up and try to re-position it.
Also, how do you know when the flow rate is right? I originally set it to 2 drops per minute but this covered the back wheel in oil. I now have it set so there is hardly any fling onto the back wheel, my reasoning being if the the oil is being thrown off the chain it can't be lubricating it. Chain seems ok after 4k miles like this.
A tad busy jans1971 Bikes - Talk & Issues 1 13-12-08 09:49 PM
Not gone, just busy! slark01 The Border Patrol 2 23-07-08 09:38 PM
busy busy day kitkat Idle Banter 7 30-06-08 12:59 PM
Been busy today....... jumjum_0214 Photos 16 13-03-08 10:53 AM
Who's busy this weekend?? Stig Soho Massive 3 03-11-04 07:07 AM
