Old 12-04-06, 01:31 PM   #11
Peter Henry
Halonic...Your a very funny guy...well ok I stretch the point a little. :P
Old 12-04-06, 01:32 PM   #12
Skip
Skip's Avatar
Originally Posted by Jase22
The model with the twin exausts at one side looks far better, the Sport 1000.
See here
Now that I quite like....
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 12-04-06, 01:32 PM   #13
Halonic
Originally Posted by northwind
I wonder what Ducati think they're making, wedging all those modern bits on a retro. It just looks ridiculous. You can make a modern-ish retro without totally abandoning the character of the original, just look at the Bonnies, but these things are just awful.
now theres two ways to look at that, it could be said that triumph are ripping people off. In these days of USD forks, floating discs and radial callipers, anything without them could well be described as budget, yet triumph charges premium prices for less then top spec equipment, under the banner of "retro". A good comparison is the thruxton and the sport classic, similar price but a world apart spec wise.
Just because thats how things were in 1967 doesnt mean we should be still doing it. Time and technology move on, and the Ducati retro range combine the best aspects of retro gear with modern tech.
If you want true retro, seek thee Classic Bike Guide and get ready with that oily rag. If you want retro looks and none of the hassle well....
Now wheres me Norton Commando?
Old 12-04-06, 01:46 PM   #14
tricky
THeres somthing about all of these retro bikes that doesn't look quite right to me, something in the proportions of bike that is just ever so slightly off.
Old 12-04-06, 01:49 PM   #15
Jase22
It's probably a combination of smaller wheels and shorter wheelbase on the new "retro" bikes.
Didn't Vincent used to run something like 21" wheels?
Old 12-04-06, 01:50 PM   #16
Peter Henry
Tricky...That is simply due to the era in which you live in. Retro is never going to compare like for like with the modern bikes we see today. They are just not as appealing,however someone from that era would suggest the modern bikes look like toys rather than real machines! It's all about perspective I guess.
Old 12-04-06, 01:51 PM   #17
rictus01
rictus01's Avatar
Now I see what they are doing, but to be honest, apart from the Paul Smart one, I'm not that impressed, I think Triumph do a better job on the moden retro thing.
And you can lay bets the Triumphs will be cheaper.
Cheers Mark.
Old 12-04-06, 01:56 PM   #18
Peter Henry
oooh that blue café racer type one is kinda nice? What's that one called? (Please don't say Timothy or anything else equally predictable! :P )
Old 12-04-06, 02:02 PM   #19
To me it utterly misses the point of a retro to load it up with visibly modern bits... If you want something that looks and moves like a modern sports bike, get one. You can make a retro that still looks retro without having to have a low spec- even just using RWU forks and regular calipers would make a huge difference, especially on this one where it's relatively true to the original look already.
Old 12-04-06, 02:08 PM   #20
Halonic
thats the Thruxton my good man, lovely little bike but not a patch on the Ducati Sport
hold up. I'll find some specs
edit: AHA!
got them
Thruxton:
Engine Type Air-cooled, DOHC, parallel-twin, 360 degree firing interval
Capacity 865cc
Bore/Stroke 90 x 68mm
Compression Ratio 9.2:1
Fuel System Twin carburettors with throttle position sensor and electric carburettor heaters
Ignition Digital - inductive type
Transmission Primary Drive Gear
Final Drive X ring chain
Clutch Wet, multi-plate
Gearbox 5-speed
Cycle Parts Frame Tubular steel cradle
Swingarm Twin-sided, tubular steel
Front Wheel 36-spoke, 18 x 2.5in
Rear Wheel 40-spoke, 17 x 3.5in
Front Tyre 100/90 18
Rear Tyre 130/80 R17
Front Suspension 41mm forks with adjustable preload
Rear Suspension Chromed spring twin shocks with adjustable preload
Front Brakes Single 320mm floating disc, 2 piston caliper
Rear Brakes Single 255mm disc, 2 piston caliper
Dimensions Length 2150mm (84.6in)
Width (Handlebars) 695mm (27.4in)
Height 1095mm (43.1in)
Seat Height 790mm (31.1in)
Wheelbase 1490mm (56.7in)
Rake/Trail 27 degree/97mm
Weight (Dry) 205kg (451lbs)
Fuel Tank Capacity 16 litres (4.2 gal US)
Performance (Measured at crankshaft to DIN 70020) Maximum Power 70PS (69bhp) at 7,200 rpm
Maximum Torque 72Nm (53ft.lbf) at 6,400rpm
Colours Jet Black/Silver, Racing Yellow/Silver, Caspian Blue/Silver
Price £5,699.00 'on the road' retail
Ducati Sport:
Frame: Tubular steel trellis
Wheelbase: 1425 mm / 56.1 in
Rake: 24°
Front Suspension: 43 mm upside-down fork
Front Wheel Travel: 120 mm / 4.7 in
Front Brake: 2 x 320 mm semi-floating discs, 2-piston, 2- sintered pad floating caliper
Front Wheel: Spoke wheel with aluminium rim 3.50 x 17
Front Tyre: 120/70 R 17
Rear Suspsension: Sachs fully adjustable monoshock absorber on the left side
Rear Wheel Travel: 130 mm / 5.1 in
Rear Brake: 245 mm disc, 1-piston floating caliper
Rear Wheel: Spoke wheel with aluminium rim 5.50 x 17
Rear Tyre: 180/55 R 17
Fuel Capacity: 15 L / 3.9 US gal (includes 3.5 L / 1 US gal reserve)
Weight: 179 kg / 394 lbs
Seat Height: 825 mm / 32.5 in
Instruments: Electronic panel: speedometer, rev counter, high beam indicator, turn signals, oil pressure warning light, low fuel warning light, LCD clock, immobilizer
Warranty: 2 years unlimited mileage
Tank and Fairing Colours: black-red-burnt yellow
Frame and Wheel Colours: (black-black-aluminium) (red-black-aluminium) (burnt yellow-black-aluminium)
Versions: Single seat
Type: L-twin cylinder, 2 valves per cylinder Desmodromic; air cooled
Displacement: 992 cc
Bore and Stroke: 94 x 71.5 mm
Compression Ratio: 10:1
Power: 67.7 kw - 92 hp @ 8000 rpm
Torque: 9.3 kgm (67.3 lb-ft) @ 6000 rpm
Fuel Injection: Marelli electronic fuel injection, 45 mm throttle body
Exaust: Black exhaust system with two right-side mufflers
Emissions: Euro 3
Transmission
Gearbox: 6 speed
Ratio: 1st 37/15, 2nd 30/17, 3rd 27/20, 4th 24/22, 5th 23/24, 6th 24/28
Primary Drive: Straight cut gears; ratio 1.84
Final Drive: Chain; Front sprocket 15; Rear sprocket 38
Clutch: Dry multiplate with hydraulic control
Retail list price: £7495 (From 3X motorcycles)
So for an extra two grand, you get a modern, retro styled bike, rather then the stripped retro from Triumph
retro sweets. Gene genie Idle Banter 27 16-02-09 06:11 AM
Retro fit original exhaust Cyclops SV Talk, Tuning & Tweaking 2 20-06-07 10:36 AM
retro games hovis Idle Banter 9 26-10-06 07:18 AM
SV Retro Style Bodywork kciN SV Talk, Tuning & Tweaking 1 13-08-06 11:08 AM
Retro Mario Fun TSM Idle Banter 1 07-02-06 10:46 AM
