Old 15-04-06, 07:05 PM   #11
HalesowenNick87
cheers guys.. im not bothered weather if it is or not, was just wondering.. lol .. its such a great bike!!!
Old 16-04-06, 10:48 AM   #12
GSXR Carlos
Originally Posted by glade
Originally Posted by Carl PO51 MYV
i could comfortably sit at 90mph in 6th at 7000 rpm, now mine does 100mph at 7000 with no mods other than restrictors removed
so yeah, that souds about right all depends on the wind behind you
don't want to sound like a nobber but surely the power makes no difference to the gear ratios - therefore to the speed at certain revs.
my bike was restricted by the amount of air that travels from the airbox to the carbs, therefore it seems that more air at 7k means more power and then more speed, or maybe my carbs are outta sync who knows
Old 17-04-06, 05:46 AM   #13
jcleare
This is my first post. Is this forum mainly based in Europe?? I'm in the U.S. What restructions??? I topped my 650s at 10k rpm's at 137mph. Just wanted to see what she'll do. Don't plan on doing it again.
Old 17-04-06, 07:28 AM   #14
jenni
Originally Posted by HalesowenNick87
It just feels real fast, ha! probably cus my last bike was a 1979 superdream, true more power is more fun... and i have got the certificate...
thanks
Im also having problems with islands and conering, some corners im fine but some i find myself creeping round like an old granny, i no i have to lean the bike but it just scares me and i dont rely no how to do it, i used to be fine with my smaller less powerful bikes but the sv scares me a bit, i'd a appreciate any tips or advice...
cheers
Hiya, the sv will feel like a huge jump but you'll soon get used to the extra power.
Give it time to get used to the handling. i role a 125 scoot before the sv and corners can feel quite scarey at first. I think this is partly due to the fact that the sv is quite long.
Practice, practice practice. I used to do all sharp corners in first and crawl around them sometimes needing the clutch if I was going that slow! however you will soon get to know how the bike feels in corners and get more confident.
Do it at your own pace, you'll get there
Old 18-04-06, 09:50 AM   #15
Steve_God
Being a new rider I had my k6 restricted from new till not long after the first service...
(I now use it unrestricted for 'Track-Use' only of course ) hehe
Restricted: 113 mph (7.5k RPM)
Unrestricted: 140 mph (10.5k RPM)
(Red Line is 11k RPM)
Main difference is the length of time it takes...
When it's restricted, you open it up and it feels like it's being bogged down and really unhealthy. Unrestricted it feels like it's running properly
(For anyone not in the UK... if you have had your full bike licence under 2 years {or haven't completed a 'Direct Access' course for those over 21} you have to have the bike restricted to 33bhp... officially :P)
Old 15-09-06, 01:01 PM   #16
SV650_K03
Can anyone tell me, how to remove the restriction?
Old 15-09-06, 01:15 PM   #17
TSM
The Sick Man
TSM's Avatar
No, revs are directly linked to speed unless your clutch is slipping
Old 15-09-06, 01:16 PM   #18
Stu
Trinity
Stu's Avatar
Pass a DAS exam or wait 2 years after you pass a restricted exam.
HTH
Old 15-09-06, 01:21 PM   #19
jambo
jambo's Avatar
For pointys you need to unplug your restricted ECU and plug in you "old" full power one, you will still have this because no garrage has ever swapped them over and kept your ECU to sell on to another customer
FOr curvey's there are 2 methods, one stops the carb sliders from opening all the way, TSM did a "how to" on removing these but they are quite uncommon. More usually popping the carbs off will show you a metal disc between the carb and engine block restricting airflow, pop it out, refit carbs and done.
TSM's guide is here: http://forums.sv650.org/viewtopic.ph...ht=restriction
Old 17-09-06, 11:14 PM   #20
Steve_God
HTH
Say you want the standard ECU for 'Track Use' and get them to write a letter for you to sign to say you will replace your restricted ECU as per your licence. Removes their obligation to keep it!
Restriction GeneticBubble Bikes - Talk & Issues 18 23-06-12 10:23 PM
New restriction suzsv650 SV Talk, Tuning & Tweaking 6 20-04-09 10:25 PM
Restriction Jebiah Bikes - Talk & Issues 3 11-07-06 09:11 PM
33 bhp de restriction HELP andy gooding Bikes - Talk & Issues 33 19-02-06 12:01 PM
restriction jonnyb SV Talk, Tuning & Tweaking 27 27-04-05 08:51 AM
