Old 01-05-06, 07:43 PM   #11
BILLY
Originally Posted by RandyO
more than likely your regulator/rectifier is fried, it is the weak point in most motorcycle charging systems, including the SV
as RandyO said have it checked and replace if necessary or you'll fry another battery!!!!!
Old 01-05-06, 08:07 PM   #12
branny
interesting!
cheers guys..... so where is the regulator, how do i check it..... and how much is a new one????
Old 01-05-06, 09:24 PM   #13
LondonLad
Default rectifier
does sound identical to the problem i had - when the rectifier was got to some of the contact points had fried. these were replaced and the problem was solved.
Old 01-05-06, 09:52 PM   #14
BILLY
It's on the left hand side behind the tail plastics!!!
Old 01-05-06, 10:06 PM   #15
Wrong, reg/rec is on the right.
Charging problems? Please ignore the "I think" and the "it oughts" and read this thread:
Clickety click
Reg/rec and alternator tests are included, as are suggestions as to what you might do to resolve the situation. Enjoy and digest.
PS: Search.
Old 01-05-06, 10:07 PM   #16
BILLY
Sorry I get confused
Old 02-05-06, 08:31 AM   #17
branny
cheers mr squid.
i will try that tonight.,.. even though that test involves starting the bike! which may be difficult
1 question though........ if the battery isnt flat.... how can it be a charging problem??????
i gotta say, i like the idea of this rectifier jobby being the solution but i keep thinking starter motor. what would a duff starter motor do?
Old 02-05-06, 11:13 AM   #18
branny
further to previous post.....
ok, im sold on the idea of it being a charging system fault.
the battery obviously doesnt have enough current to start the engine...
so, im hoping the only culprit is the reg/rec, and i havent got a burnt out alternator.
i just hope this hasnt wrecked my new £35 battery!!!
Where can i get a reg/reg cheap??? Suzuki want £130 +vat !!!!!!
A new alternator is £300+
this is a nightmare....
any good bike scrappers in preston area???
will this one on ebay be any use? off a gs650
http://cgi.ebay.co.uk/SUZUKI-GS-650-...QQcmdZViewItem
Old 02-05-06, 07:43 PM   #19
branny
well... after a good while FINDing the regulator / rectifier, i did some testing-
with a battery that gave 12.8v-
no lights, idle - 14.3V
no lights, 5000 rpm - 13.9V
lights idle - 12.3V
lights 5000 - 12.5V
engine idling, RR red/black plug disconnected -
Batt + ----> RR red = 0.1V
Batt - ------> RR Black = 0.05 ish V
PLEASE HELP ME !!!!!!
My battery runs flat and there is oil in the alternator casing. Dirk Eisner SV Talk, Tuning & Tweaking 15 18-02-08 07:58 PM
New Alternator ... How much? The Bride SV Talk, Tuning & Tweaking 13 18-02-07 10:34 AM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
Is it my Battery or Reg/Rec or Alternator?..i just dont know Spiderman Bikes - Talk & Issues 11 21-05-06 02:23 PM
battery or alternator? muzikill SV Talk, Tuning & Tweaking 5 16-01-06 12:45 PM
