#11 |
The calipers are the same so I don't see why not.
#12 | |
#13 | ||
#14 | |||
#15 |
Got calipers yet?
#16 | |
#17 | ||
(though then I'd like to point out that the cost of rebuilding a standard SV front end to a decent quality, and then these brackets, and the calipers, will most likely be more than a GSXR front end swap)
#18 |
Yes, you will get more dive with these, because the brakes will actually work, especially under track/race conditions. Stock calipers are garbage. IMHO, they are so bad they are semi-dangerous for track usage. They don't stop and require way too much lever pressure (and offer unacceptable 'feel')...and then they still don't shave off speed to an acceptable level. Again, IMHO.
The GSXR conversion fixes both problems. Fork springs are $100 and should be on any/every bike regardless of which calipers are used. Again, the stock fork springs on the SV are garbage as well. If your brakes work adequate for you, then the conveersion is overkill. If you are not happy with your brake performance, then is is the answer. Fork springs are required either way. |
#19 |
I have Race tech emulators, springs and heavier oil. I have a fork brace also to add stiffness. My limiting factor is the calipers. Don't make me buy a HONDA.
#20 |
Razor- I'd get the calipers! Should be fantastic with that setup.
Going to have to totally disagree with Highspeedassault on the stock calipers, to be honest, and there's plenty of others that would say the same. But that's not to say it's not worth replacing them with better. There's no more total power there than you can get from a well sorted set of standard calipers (talking nothing more than keeping them in top shape, and a set of good pads, plus braided lines)- you can lock the front in the dry, or flip the bike with standard after all. But total power's not the issue, what you do with it is, and the GSXR calipers give better feel and feedback as he says. It's incredibly difficult to use the full potential of the SV calipers for that reason, which is why you can throw of speed faster with the 4-pots. In wet or bad conditions, the progressiveness and feel is just so much better.
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads | sv-racing-parts | SV Talk, Tuning & Tweaking | 42 | 15-09-11 10:27 PM |
Gsxr Brake disks | sv_rory | Stuff Wanted | 9 | 04-02-09 05:23 PM |
torque wrench - conversions | skint | Bikes - Talk & Issues | 0 | 12-03-07 09:27 PM |
GSXR 600 Brake Pedal? | cb9002 | SV Talk, Tuning & Tweaking | 3 | 27-01-07 12:04 PM |
Front End conversions | Blue_SV650S | SV Talk, Tuning & Tweaking | 27 | 18-06-06 05:07 PM |
