Old 24-04-06, 02:47 PM   #11
Ash999
to the last few questions, it vibrates quite a bit on idle and when riding. Especially through the tank. Serviced - well needs it but has only been like spark plugs, oil and filter, tyres, brakes, change regularly but not more than that. I seem to remember my sister synched the carbs about 2 1/2 years ago. The exhaust is quite sooty! but not overly, the airfilter hasnt been touched since then as well.
So, in the greater scheme of things, just give the bike a bloody good service, and c if it rides well, then consider rejet if i really want to.
Just thinking if i need to replace airfilter (is it reuseable?) then aint i best getting a BMC and then rejetting after all that, or just putting a new standard one in?
Old 24-04-06, 03:03 PM   #12
Viney
Carbs can go out of sync in about a week, so they are probably well out. That could be your problem straight out
Old 24-04-06, 03:10 PM   #13
jambo
jambo's Avatar
Go through everything for a main service, an airfilter that's 2 1/2 years old with any sort of regular use will be pretty gummed up and quite restrictive, which might be why your exhaust is sooty. I'd go for a fresh BMC or other washable filter, and possibly a little dyno time to check if it needs re-jetting?
:edit:
Like Viney says, carbs are probably out but not worth checking till there's a clean filter, plugs etc, and after 2 years, have the valve clearances been checked? Carb sync is affected by everything else so get the bike up to scratch then do it.
Old 24-04-06, 07:28 PM   #14
So, is the fuel smell when running carb balancing or fuel mixture
Could be any of the above as well as float height/needle wear.
First thing is to check it's all working right, before jumping into things like jetting etc. A basic reset all to standard is the best first option.
Name that tune DarrenSV650S Idle Banter 3 20-11-07 10:26 PM
tune Wideboy Idle Banter 2 04-08-07 02:00 PM
Theme Tune tricky Idle Banter 28 07-03-07 11:01 PM
What is that tune... Anonymous Idle Banter 7 31-03-06 09:57 AM
Bagging out after tune up RGSV Bikes - Talk & Issues 8 06-06-05 11:01 PM
