Old 28-04-06, 09:21 AM   #11
rictus01
rictus01's Avatar
Originally Posted by tomjones2
Originally Posted by rictus01
I'm looking to get a replacement gear selector today......I'm assuming it's an easy job to fit a new one......
riddiculous easy, and the gear selecter cost about £30
I think I know how to fit one thanks
Old 28-04-06, 09:32 AM   #12
kciN
After all that cleaning eh!!
Sorry to hear about your bad luck, but your ok, main thing..
Still a nice bike BTW!!
Old 28-04-06, 09:50 AM   #13
tomjones2
sorry rictus, i though it was streetfighter who posted that
Old 28-04-06, 09:58 AM   #14
Davies
Originally Posted by thor
Bummer. I'm assuming that you are ok?
Yeah cheers, just a bruised hip and a scrape on my elbow......and a dented ego
Old 28-04-06, 06:12 PM   #15
donniej
If you didn't even scrape the tank then you did just fine. Sadly the tachometer always gets it on our bikes
I wish I could remember how many times I've gone down..... I'm sure it's probably a pretty big number!
Old 29-04-06, 01:37 PM   #16
Originally Posted by "rictus01
two minute job to change the gear lever, bolt out of coller on gear shaft, put off the coller, undo peg bracket,undo peg from the back ( you may want to re-fix the bracket to the frame backwards/ bolt facing out , to get some leverage), slip the selector lever off and replace, re-fit in reverse order.
Unless the bolt's stuck, and you have to factor in extra time for swearing
Old 29-04-06, 02:43 PM   #17
Warthog
Cheers Mark.
I need to change the rear brake lever on my neighbours SV tomorrow. Is it the same procedure as for the gear lever? And also, er, could you word it a little more simply I don't know what a coller or peg brackets are..
DO you undo the whole plate that has the footpeg assebly attached to it, or can you access the bolts round the back ok with it still on? Also, they don't look like regular bolts to me, more like notched wheels, like on the clutch lever adjuster.
Sorry to be such a n00b!
Old 29-04-06, 10:07 PM   #18
madmal
glad to hear you are ok mate
I only popped out for a coffee... Lozzo Idle Banter 6 05-04-09 10:59 AM
Just popped in........ Glynmitch Idle Banter 1 13-04-07 09:17 PM
shall i pop my euro cherry? gazman Bikes - Talk & Issues 12 11-01-07 07:26 PM
Pillion Cherry popped!!! Kinvig Bikes - Talk & Issues 12 25-09-06 09:43 AM
Dukes Pass Cherry Popped! Cam_73 SV Ecosse 5 30-07-06 08:13 PM
