Old 02-05-06, 11:01 PM   #11
Bloody awful, those things. Mityvac does the job far better, and without the bodging.
Old 02-05-06, 11:07 PM   #12
TSM
The Sick Man
TSM's Avatar
You could try pushing the pistons in the calipers all the way back and re blead, that way it may dislodge any air that could have become trapped behind the piston, it also has less of a chamber to have oil in and so its much quicker.
I find tapping the calipers with the end of a screwdriver while bleeding helps moving air bubbles out.
I did my new calipers in about 5 mins the way i discribed.
Old 03-05-06, 02:54 PM   #13
True.
Mityvac is still un-necessary though.
Old 03-05-06, 03:37 PM   #14
Yup, but still nice to have, when you can't bleed brakes for toffee
Old 03-05-06, 03:41 PM   #15
Grinch
That would be me then... I've screwed up every set of brakes I've ever worked on.
Old 03-05-06, 04:05 PM   #16
I can do it... But it always works like this. Basically, I repeat the process over and over endlessly and nothing happens, then it suddenly works without changing anything. Or it works first time. Or it just doesn't work for ages... All using the typiacl bit of clear hose, squeeze and bleed technique. Drives me insane, I wouldn't mind if it either worked or didn't but when it doesn't work for ages then suddenly works it's maddening.
Honestly, the hardest bit of teh front end swap for me was bleeding the *(^&ing brakes.
Old 03-05-06, 04:46 PM   #17
Razor
Tie the brake leaver to the grip, leave overnight. Rinse and repeat...
Old 03-05-06, 04:47 PM   #18
TSM
The Sick Man
TSM's Avatar
Dont do it too much or the MC & brake seals may pop or get damaged.
Old 03-05-06, 04:57 PM   #19
embee
embee's Avatar
I'm firmly in the mityvac camp
The squiddly one insists they are not essential, well no they're not, but I've never had any issues getting properly bled brakes on anything first go in only a few minutes using one.
How essential does it have to be to avoid all the hassles some folks seem to have getting a properly bled system? That's what tools are for, making life easier
A good advantage of the mityvac is that you can empty out the reservoir first before adding any new fluid, avoiding mixing old/new or risking getting air in when pumping low. Yes there are other ways of emptying a reservoir without one, but it's easy with it.
You pays your money.................
Old 03-05-06, 05:01 PM   #20
Razor
I'm gonna ask a nursey for a big syringe tommorrow, cheap as junkie breath.
Double banjo brake bolt with bleed nipple northwind For Sale - SV's and SV related items 6 13-02-10 06:53 PM
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
brake caliper bleed nipple size stuballs SV Talk, Tuning & Tweaking 6 02-12-08 05:28 PM
Front brake question Caddy2000 SV Talk, Tuning & Tweaking 16 07-03-07 09:11 PM
Brake Bleed / Fluid question. SpankyHam SV Talk, Tuning & Tweaking 2 02-06-06 12:51 PM
