Old 27-05-06, 08:51 PM   #11
mine were from Heine gericke -
£1.99 each
Old 28-05-06, 08:46 AM   #12
Philbo
Do a google seaerch for RS components, they're good. Even try Maplins online, I'd be supprised if they don't have anything. E-bay might be worth a look.
These size resistors or not uncommon, and don't let anyone tell you otherwise. I'ts not the golden fleece we're searching for!
Or if you're really struggling you can use a different set-up.
Instead of 1 off 21 watt 7 ohms resistor per indicator, you can use 2 off 14 ohm 11 watt resistors. Just place the resistors back to back, twist the wires together at both ends, and hey presto you've just made a 22 watt 7 ohm resistor. If you can't get 14 ohm, 15 or even 16 would still work in the same way.
Regarding the wattage, anything over 21 is good. If you using 2 or more resisitors to make up the desired value, they must add up to at least 21 watts, and in an "even" manor. eg 2 off 11 watts, not 1 at 7 watts and 1 at 14 watts.
Hope this helps.
Old 28-05-06, 11:09 AM   #13
muffles
http://rswww.com is what you want used to have to use them a lot at an old job...
LED Flash rate relays... DF! SV Talk, Tuning & Tweaking 4 17-09-08 06:47 AM
Not the normal type of indicator flash rate problem.... DarrenSV650S SV Talk, Tuning & Tweaking 11 03-07-08 06:42 PM
Led indicator flash rate TC3 SV Talk, Tuning & Tweaking 16 11-12-05 08:15 AM
LED Indicators - Flash Rate mastiffmat SV Talk, Tuning & Tweaking 3 09-11-05 04:54 PM
Flash rate Problems?? (Non LED) Sledgehammer SV Talk, Tuning & Tweaking 7 15-08-05 08:45 PM
